BIRT Chart Problem [message #81445] |
Fri, 04 April 2008 09:25  |
Originally posted by: anupgokhale.rediffmail.com
Hello all.
I am using BIRT inside a RAP application. The problem I am facing is
that the chart placed on a BIRT report does not get displayed, when the
RAP application is launched in a separate browser. The strange part is,
the chart is displayed properly if the RAP application is launched in
the internal eclipse browser.
Any help is appreciated.
Anup Gokhale
Re: BIRT Chart Problem [message #85063 is a reply to message #84630] |
Sun, 27 April 2008 23:35   |
Hi Gustavo,
Download the BIRT runtime from the BIRT project downloads, unzip the
files and copy the plug-ins into the plugins folder of the RAP
installation. Then just reload the RAP platform.
Anup
Gustavo wrote:
> Hi Anup
> I have tried to integrate BIRT with RAP and it seems, although I
> installed BIRT correctly, that I can't retrieve the plugins to use them
> in my project. I believe is related with the RAP Target Source for Eclipse.
> Please, do you have any hints on this issue? I will appreciate any help
> Best Regards
> Gustavo
> Anup Gokhale wrote:
>> Hello all.
>> the RAP application is launched in a separate browser. The strange
>> part is, the chart is displayed properly if the RAP application is
>> launched in the internal eclipse browser.
>> Regards,
>> Anup Gokhale
Re: BIRT Chart Problem [message #85135 is a reply to message #85063] |
Mon, 28 April 2008 05:06   |
Hi Anup,
would you mind to write a little tutorial for non-BIRT users how to
setup and use BIRT in a RAP application? We are really interested to see
such a combination and I would really love to see a little sample
application.
Greets
Benny
Anup Gokhale wrote:
> Hi Gustavo,
> Regards,
> Anup
> Gustavo wrote:
>> Hi Anup
>> them in my project. I believe is related with the RAP Target Source
>> for Eclipse.
>> Best Regards
>> Gustavo
>> Anup Gokhale wrote:
>>> Hello all.
>>> Regards,
>>> Anup Gokhale
Re: BIRT Chart Problem [message #85659 is a reply to message #81445] |
Wed, 30 April 2008 09:59  |
I have little bit confuse ,, if your using org.eclipse.birt.chart.ui ,
then this plugin depend on org.eclipse.ui .. So how u get ur plugin works.
Actually Am using birt report designer but it is based on RCP ,,, So i
guess we should rewrite the birt plugins with RAP...
Salwa
FUDForum. Page generated in 0.06533 seconds
