Re: Metamodel in workspace in QVTO Problem [message #818148 is a reply to message #817876] |
Sun, 11 March 2012 01:10  |
Hi Gustavo
What you describe is a workaround that works for you.
I am successfully using QVTo for a cascade of transformations without
generating a Java model, let alone a Java editor.
Ed Willink
On 10/03/2012 20:15, Gustavo Bartolomeo wrote:
> Thanks Ed,
> In this case the problem was the use of dynamic instances.
> I built an editor for my local metamodel.
> Then create an instance using the editor, and the transformation worked!
Re: Metamodel in workspace in QVTO Problem [message #818153 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818158 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818163 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818168 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818173 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818178 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
Re: Metamodel in workspace in QVTO Problem [message #818183 is a reply to message #817876] |
Hi Gustavo
Ed Willink
> Thanks Ed,
FUDForum. Page generated in 0.33451 seconds
