[ATL] Launch ATL from Java [message #81680] |
Tue, 20 May 2008 05:56  |
Originally posted by: amivi.fagbegnon.gmail.com
Hi everybody,
I am trying to launch transformation from Java code . I am using uml 2.1.0
models.
Here the code to load my models:
URL umlmmurl = new
URL(" file:/D:/workspaceSFD2CA/TestTransfos/src/resources/UML.ecor e ");
I try to load with uri but I had these errors
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.Socket.connect(Socket.java:516)
at java.net.Socket.connect(Socket.java:466)
at sun.net.NetworkClient.doConnect(NetworkClient.java:157)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:365)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:477)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:214)
at sun.net.www.http.HttpClient.New(HttpClient.java:287)
at sun.net.www.http.HttpClient.New(HttpClient.java:299)
at
sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient (HttpURLConnection.java:796)
at
sun.net.www.protocol.http.HttpURLConnection.plainConnect(Htt pURLConnection.java:748)
at
sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLC onnection.java:673)
at
sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:917)
URL xmlmmurl = new
URL(" file:/D:/workspaceSFD2CA/TestTransfos/src/resources/XML.ecor e ");
uml2MM_MDR = mdramh.loadModel("UML2", mdramh.getMof(),
umlmmurl.openStream());
xmlMDRmm = mdramh.loadModel("XML", mdramh.getMof(), xmlmmurl.openStream());
I get the errors below:
Initializing MDR...
org.netbeans.lib.jmi.util.DebugException: No tag specifying a namespace
uri is attached to MofPackage Model
at
org.netbeans.lib.jmi.xmi.XmiContext.findOutermostPackages(Xm iContext.java:272)
at org.netbeans.lib.jmi.xmi.XmiContext.setVersion(XmiContext.ja va:249)
at org.netbeans.lib.jmi.xmi.XmiElement$Document.<init>(XmiElement.java:94)
at
org.netbeans.lib.jmi.xmi.XmiSAXReader.startElement(XmiSAXRea der.java:169)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(XMLDTDValidator.java:798)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:878)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDispatcher.scanRootElementHook(XMLDocumentScannerI mpl.java:1157)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1794)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.netbeans.lib.jmi.xmi.XmiSAXReader.read(XmiSAXReader.java :136)
at org.netbeans.lib.jmi.xmi.XmiSAXReader.read(XmiSAXReader.java :98)
at org.netbeans.lib.jmi.xmi.SAXReader.read(SAXReader.java:56)
at
org.atl.engine.repositories.mdr4atl.ASMMDRModel.loadASMMDRMo del(ASMMDRModel.java:348)
at
org.atl.engine.repositories.mdr4atl.AtlMDRModelHandler.loadM odel(AtlMDRModelHandler.java:93)
at SFD2CALauncher.initMDR(SFD2CALauncher.java:159)
at SFD2CALauncher.<init>(SFD2CALauncher.java:101)
at SFD2CALauncher.getATLTransformations(SFD2CALauncher.java:231 )
at SFD2CALauncher.main(SFD2CALauncher.java:435)
Error while reading UML2:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at SFD2CALauncher.initMDR(SFD2CALauncher.java:160)
Error while reading XML:
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'eGenericType'
not found. (UML2, 63, 98)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeatu re(XMLHandler.java:1215)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeatu re(XMLHandler.java:1185)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.handleUnknownFeatu re(XMIHandler.java:87)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1146)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:466)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:65)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:449)
at
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:73)
at
at
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1693)
at
at
at
at
at
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:140)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:169)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:977)
at
org.atl.engine.repositories.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:341)
at
org.atl.eclipse.engine.AtlEMFModelHandler.loadModel(AtlEMFMo delHandler.java:110)
at SFD2CALauncher.initEMF(SFD2CALauncher.java:209)
at SFD2CALauncher.<init>(SFD2CALauncher.java:102)
no type named 'Root' in metamodel 'XML'
at
org.atl.engine.repositories.mdr4atl.ASMMDRModel.newModelElem ent(ASMMDRModel.java:177)
at org.atl.engine.vm.nativelib.ASMModel.newModelElement(ASMMode l.java:74)
at org.atl.engine.vm.nativelib.ASMModel.newModelElement(ASMMode l.java:62)
at
org.atl.engine.injectors.xml.XMLInjector.startElement(XMLInj ector.java:141)
at
org.atl.engine.injectors.xml.ProtectedHandler.startElement(P rotectedHandler.java:38)
at
at
at
at
at
at
at
at
at
at
at javax.xml.parsers.SAXParser.parse(SAXParser.java:176)
at
org.atl.engine.injectors.xml.XMLInjector.performImportation( XMLInjector.java:91)
at org.atl.engine.injectors.xml.XMLInjector.inject(XMLInjector. java:74)
at SFD2CALauncher.injectXMLModelFromFile(SFD2CALauncher.java:37 4)
at SFD2CALauncher.transformOnetoOther(SFD2CALauncher.java:423)
at SFD2CALauncher.main(SFD2CALauncher.java:438)
no type named 'Text' in metamodel 'XML'
at
at
org.atl.engine.injectors.xml.XMLInjector.characters(XMLInjec tor.java:117)
at
org.atl.engine.injectors.xml.ProtectedHandler.characters(Pro tectedHandler.java:30)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .characters(AbstractSAXParser.java:570)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanContent(XMLDocumentFragmentScannerImpl.java:1 062)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1649)
at
at
at
at
at
at
at
at
at
at
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:220)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:872)
at
at
at
at
at
at
at
at
org.atl.engine.injectors.xml.XMLInjector.endElement(XMLInjec tor.java:170)
at
org.atl.engine.injectors.xml.ProtectedHandler.endElement(Pro tectedHandler.java:46)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endElement(AbstractSAXParser.java:633)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:221)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at SFD2CALauncher.injectXMLModelFromFile(SFD2CALauncher.java:37 4)no type
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.jav a:1241)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1685)
at
at
at
at
at
at
OK
Re: [ATL] Launch ATL from Java [message #81770 is a reply to message #81680] |
Tue, 20 May 2008 14:27   |
Originally posted by: milan.milanovic.org
Hi Amivi,
I supose that you are using ATLTransformations class ?
Amivi FAGBEGNON wrote:
> Hi everybody,
> models.
> URL umlmmurl = new
Please try to use relative path. For example, if you have
ATLTransformations class and CLASSPATH set to c:\java and you have
metamodels folder in it, you can define URL like this:
URL umlmmurl =
ATLTransformations.class.getResource("metamodels/UML.ecore");
> at
> at
> at
> at
> URL xmlmmurl = new
No, mdramh is MDR AtlModelHandler, and when you work with .ecore files
then you need EMF model handler (emfamh). Please, learn little bit about
ATL, MDE and model handlers.
> Initializing MDR...
> at
Regards, Milan Milanovic
Re: [ATL] Launch ATL from Java [message #81885 is a reply to message #81817] |
Wed, 21 May 2008 05:54  |
"Amivi FAGBEGNON" <amivi.fagbegnon@gmail.com> wrote in message
news:c5c8e6319e423823279fcaf581c31bf7$1@www.eclipse.org...
> Thanks for your help.
> Concerning the using of relative path... I tried but it not work. I get an
> java.lang.NullPointerException error. I have to set the class and
> classpath to c:\java before it work?
Yes, if you have there your class, as it is written in "Installations
steps".
> Indeed I try to adapt the ATLTransformations class to my needs.
> In the step 3 of Installation instructions, you say :
> 3. Use it in your application:
> import atl.ATLTransformations;
> and as it show in docs.
> Where are these docs?
You have included "docs" folder in .zip bundle, it is actually a javadoc.
> Can I find projects in use case which use the bundle?
I'm sending you an running example of ATLTransformations class in attach.
Note that I'm using MDR, but it can be switched to EMF.
Regards, Milan
> Amivi
FUDForum. Page generated in 0.04383 seconds
