Home » Eclipse Projects » Dali » Can't add entity class that doesn't have @table into the diagram
Can't add entity class that doesn't have @table into the diagram [message #816233] Thu, 08 March 2012 10:26 Go to next message
I'm using Dali's Diagram Editor v.1.0.1.
I've created a diagram and in it I've created a 'Inherited Entity'.
When I try to drag the generated MappedSuperclass1 drop it into the diagram, another Entity# is created. The same occurs when I try to do the same with a entity that doesn't have @table.
It's a bug ?
regards,
Cristiano
Re: Can't add entity class that doesn't have @table into the diagram [message #816258 is a reply to message #816233] Thu, 08 March 2012 11:12 Go to previous messageGo to next message
Hi Cristiano,
For the current versions of the Eclipse, this is the expected behavior. We had decided that only the entities should be shown in the diagram editor.
Nevertheless there is a proposed feature for visualizing the MappedSuperclasses which will be part of the Juno Eclipse.
Petya
Re: Can't add entity class that doesn't have @table into the diagram [message #816292 is a reply to message #816258] Thu, 08 March 2012 11:57 Go to previous message
Hi Petya,
thanks for clarifying...
regards,
Cristiano
Previous Topic:Generate tables from entities stop to work after convert JPA into a OSGi project
Next Topic:Preselected JPA Platform and Implementation on JPA Facet page?
Current Time: Sun Jul 27 16:17:34 EDT 2025
Powered by FUDForum. Page generated in 0.03443 seconds
