Home » Eclipse Projects » Remote Application Platform (RAP) » Setting "ID" for TableItem
Setting "ID" for TableItem [message #814804] Tue, 06 March 2012 17:48 Go to next message
We have a need to attach an unique ID for UI components to allow our Selenium automation tests to detect the UI components and run test. We have no problem setting IDs for most components, such as Button, Composite, even Table. Now, we want to set an ID for a table ROW. The closest Java class for a row is TableItem. When I try to set WidgetUtil.CUSTOM_WIDGET_ID in TableItem.setData(), the ID never shows up in the corresponding HTML code. Does anyone have an idea why it does not work?
Thank you,
Ronald
Re: Setting "ID" for TableItem [message #816100 is a reply to message #814804] Thu, 08 March 2012 07:21 Go to previous messageGo to next message
Hello Ronald,
currently it is not possible to set an ID on a row.
Could you further describe your use case? Do you want to have the ID of the TableItem that is currently displayed by the row to show up as the row-ID?
The other option is to have a row with a certain ID, regardless of which TableItem is displayed by this row.
Nick
Re: Setting "ID" for TableItem [message #816219 is a reply to message #816100] Thu, 08 March 2012 10:06 Go to previous message
Hi Nick,
I am Ronald's colleague. We would like each row in a table to have a unique id. The ID could be of the form "row_1", "row_2", etc ... That would suit our needs. We can then write our automation tests written in selenium to find our table, then find each child row, and perform actions against columns in the desired row.
George
Previous Topic:Setting "ID" for TableItem
Next Topic:Access Methods of Plugin
Current Time: Sat Jul 26 18:14:23 EDT 2025
Powered by FUDForum. Page generated in 0.04550 seconds
