Home » Newcomers » Newcomers » [SOLVED] Content/Code Assist Broken?
[SOLVED] Content/Code Assist Broken? [message #812788] Sun, 04 March 2012 04:52 Go to next message
When editing the code in Eclipse IDE, and i enter a method from which another method can be returned from it, no list of methods pops up when i enter a period.
Example:
Integer.parseInt(String s);
if i were to type 'Integer' then the period, no list would pop up that contains the method 'parseInt(String s)'
[Updated on: Sun, 11 March 2012 15:53] by Moderator
Re: No Method List when Period Typed [message #812982 is a reply to message #812788] Sun, 04 March 2012 12:09 Go to previous messageGo to next message
> i enter a period.
> Example:
> Integer.parseInt(arg);
> contains the method 'parseInt()'
Is there an actual JDK present (not merely a JRE)?
Re: No Method List when Period Typed [message #813109 is a reply to message #812982] Sun, 04 March 2012 16:20 Go to previous messageGo to next message
Yeah. It was working earlier, then it just stopped. I don't know why.
Re: No Method List when Period Typed [message #815749 is a reply to message #813109] Wed, 07 March 2012 20:58 Go to previous messageGo to next message
Is there a certain area in the preferences window that enables/disables it?
EDIT: It seems to be in Java > Editor > Content Assist. However 'Auto-Activation' is checked...
[Updated on: Wed, 07 March 2012 21:11] by Moderator
Re: No Method List when Period Typed [message #817208 is a reply to message #815749] Fri, 09 March 2012 14:47 Go to previous messageGo to next message
If the list still comes up when you manually hit Ctrl+Space, you can
check which characters will bring up the list automatically from the
Java Content Assist preference page, as "auto activation triggers for Java".
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: No Method List when Period Typed [message #818500 is a reply to message #817208] Sun, 11 March 2012 14:50 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Fri, 09 March 2012 14:47
If the list still comes up when you manually hit Ctrl+Space, you can check which characters will bring up the list automatically from the Java Content Assist preference page, as "auto activation triggers for Java".
It seems to ONLY come up when i manually do ctrl + space. There is a period for the activation trigger. When the window does comes up it says there are no proposals (Java Proposals is checked in the top box on the "Advanced" page)
Re: No Method List when Period Typed [message #818529 is a reply to message #818500] Sun, 11 March 2012 15:53 Go to previous message
NEVERMIND I FIXED IT.
I was typing "Integer. " outside the main method as the test. when i typed it inside the main method it worked. Now i feel dumb
Previous Topic:Downloaded Eclipse Now What???
Next Topic:libxml2
Current Time: Sat Jul 26 11:07:32 EDT 2025
Powered by FUDForum. Page generated in 0.72247 seconds
