Home » Language IDEs » Java Development Tools (JDT) » Unhandled event loop exception
icon9.gif  Unhandled event loop exception [message #815099] Wed, 07 March 2012 03:25 Go to next message
I'm converting few eclipse plugins to use eclipse version 3.7.2 (those has use eclipse version 3.4.1 before) and I'm having some problems with adapters. My plugin has it own navigator which uses tree model and it is used to open correct editors to elements. With 3.4.1 eclipse everything worked well, but now I'm having some NPE:s when I open context menu on the top of some item in navigator.
at org.eclipse.jdt.internal.ui.EditorInputAdapterFactory.getAdapter(EditorInputAdapterFactory.java:53)
at org.eclipse.core.internal.runtime.AdapterManager.getAdapter(AdapterManager.java:326)
at org.eclipse.core.internal.runtime.AdapterManager.loadAdapter(AdapterManager.java:356)
at org.eclipse.ui.internal.LegacyResourceSupport.getAdapter(LegacyResourceSupport.java:622)
at org.eclipse.ui.internal.ObjectActionContributor.isApplicableTo(ObjectActionContributor.java:223)
at org.eclipse.ui.internal.ObjectContributorManager.isApplicableTo(ObjectContributorManager.java:303)
at org.eclipse.ui.internal.ObjectActionContributorManager.contributeObjectActions(ObjectActionContributorManager.java:83)
at org.eclipse.ui.internal.PopupMenuExtender.addObjectActions(PopupMenuExtender.java:262)
at org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(PopupMenuExtender.java:339)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:342)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:473)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:469)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:495)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:247)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4881)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4557)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:256)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4206)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3748)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Is there something changed in newer eclipse versions with adapters, or what could cause this problem? I have debuged creation of adapters to elements and everything seems to work normally. I would really appreciate any help that somebody could give to me. Smile
Re: Unhandled event loop exception [message #816977 is a reply to message #815099] Fri, 09 March 2012 08:36 Go to previous messageGo to next message
Please anyone any help? Has navigation framework changed or what it might be. I'm guite stuck with this one. Sad
Re: Unhandled event loop exception [message #817074 is a reply to message #816977] Fri, 09 March 2012 10:52 Go to previous message
Man, you need to look in all the eclipse plugins' classes that your plugin is using, compare the two versions, and edit where it needs.
As simple as that, and last but not least, enjoy coding!
Previous Topic:editor window No response
Next Topic:Cannot install Google Window Builder Pro
Current Time: Sun Jun 01 18:22:53 EDT 2025
Powered by FUDForum. Page generated in 0.03322 seconds
