Home » Archived » EGL Development Tools » 0.8 M2 RUI Properties Library generated code error
0.8 M2 RUI Properties Library generated code error [message #814828] Tue, 06 March 2012 18:25 Go to next message
0.8 M2 release...
With the following:
library Properties type RUIPropertiesLibrary {}
	upsAccessKey string;
	upsUserID string;
	upsPassword string;
end
The generated Java code has an error on the import:
import eglx.ui.rui.NLSLibrary;
The error is "The import eglx.ui.rui cannot be resolved".
Need a bug submission on this or did I screw something up?
--Dan
p.s. Do you want to know about things like this on milestone releases?
[Updated on: Tue, 06 March 2012 18:25] by Moderator
Re: 0.8 M2 RUI Properties Library generated code error [message #815102 is a reply to message #814828] Wed, 07 March 2012 03:27 Go to previous messageGo to next message
My understanding is that the RUIPropertiesLibrary is only supported in JS generation, so it reports the error.
Re: 0.8 M2 RUI Properties Library generated code error [message #815316 is a reply to message #815102] Wed, 07 March 2012 08:57 Go to previous messageGo to next message
Yes, RUIPropertiesLibrary can only be generated to JavaScript. There isn't yet "generator-level validation" to handle when trying to generate a part to an invalid target language, so for now you have to be careful which generators are enabled for which parts otherwise generation could throw an error and/or produce code that won't compile/run.
-Justin
Re: 0.8 M2 RUI Properties Library generated code error [message #815435 is a reply to message #815316] Wed, 07 March 2012 11:55 Go to previous message
Oh, right. Duh. I put the RUI properties library into the "common" package. I should have put it in the "client".
You know though, while we are on the topic, I recall that even in RBD I've been jumping through hoops to be able to have the same properties available in Java that I have in JavaScript via the RUIPropertiesLibrary. In the JSF world I used getMessage() to access externalized properties and while this is still available on the Java side of a RUI app it takes extra configuration (and a copy of the properties file in a different location) to make it work.
I am wondering if anyone else thinks it would be helpful to rethink properties in terms of a "PropertiesLibrary" type that can be generated to both JS and Java?
--Dan
Previous Topic:Snippets!
Next Topic:"x is not a constructor" error using XML record definitions
Current Time: Fri Jul 18 17:19:08 EDT 2025
Powered by FUDForum. Page generated in 0.04722 seconds
