Home » Archived » Sapphire » XmlElement CDATA section
XmlElement CDATA section [message #814562] Tue, 06 March 2012 10:50 Go to next message
Hey everyone,
I have an xml file where I have a json String that is embedded in a xml element, like
<metadata>
   <![CDATA[{"xy":[50,50]}]]>
</metadata>
So what I'm currently doing is creating a ElementBindingImpl that will grab the XmlElement and read the contents of the CDATA section. Reading works fine, but the problem I'm having is when there is not a <metadata> element and I have to create one and then add a CDATA section. Is it possible to create a CDATA child node for a XmlElement
Re: XmlElement CDATA section [message #814775 is a reply to message #814562] Tue, 06 March 2012 17:00 Go to previous messageGo to next message
You would have to get the DOM node from the XmlElement convenience wrapper and use DOM API to create the CDATA section. Something like this:
XmlElement el = ...
Element domel = el.getDomNode();
CDATASection cdata = domel.getDocument().createCDATASection( "..." );
domel.insertBefore( cdata, null );
Re: XmlElement CDATA section [message #814895 is a reply to message #814775] Tue, 06 March 2012 20:27 Go to previous messageGo to next message
Easy enough, thanks!
Re: XmlElement CDATA section [message #1062726 is a reply to message #814895] Mon, 10 June 2013 10:09 Go to previous messageGo to next message
Could you please share your solution? I'm not sure where to place this wrapper code. Unfortunately, I couldn't find any CDATA example in the sample project. Thank you!
Re: XmlElement CDATA section [message #1063022 is a reply to message #1062726] Tue, 11 June 2013 16:00 Go to previous messageGo to next message
To bind to CDATA, you will need to implement XmlValueBindingImpl and use @CustomXmlValueBinding to attach it to the property. Take a look at the XmlValueBindingImpl API. The methods that you need to implement are read() and write(). Use xml() method to get a handle on XmlElement. Then see the code snippet shown previously for how to get access to DOM and manipulate CDATA nodes. See DOM API for more details on handling CDATA.
Re: XmlElement CDATA section [message #1063118 is a reply to message #1063022] Wed, 12 June 2013 07:50 Go to previous message
Hey Konstantin,
thank you for the information. Here is my solution if anyone else should have the same issue.
import org.eclipse.sapphire.modeling.xml.XmlElement;
import org.eclipse.sapphire.modeling.xml.XmlValueBindingImpl;
import org.w3c.dom.Element;
import org.w3c.dom.Node;
public class CDataXmlValueBindingImpl extends XmlValueBindingImpl {
    public String read() {
        return xml(false).getText();
    public void write(String value) {
        XmlElement el = xml(false);
        this.removeAllChildren(domel);
        Node newNode = getNode(value, domel);
        domel.insertBefore(newNode, null);
    private void removeAllChildren(Element domel) {
        while (domel.hasChildNodes()) {
            domel.removeChild(domel.getFirstChild());
    private Node getNode(String value, Element domel) {
        if (!value.isEmpty()) {
            return domel.getOwnerDocument().createCDATASection(value);
        return domel.getOwnerDocument().createTextNode(value);
And here the property annotation:
@CustomXmlValueBinding(impl = CDataXmlValueBindingImpl.class)
ValueProperty PROP_SOURCE_CODE = new ValueProperty(TYPE, "SourceCode");
Thank you!
Kon
Previous Topic:Action Handler to move value binding to top/bottom of list
Next Topic:License of the icons
Current Time: Fri Jul 25 19:53:09 EDT 2025
Powered by FUDForum. Page generated in 0.04852 seconds
