Home » Eclipse Projects » Remote Application Platform (RAP) » Qooxdoo's AutoGenerated IDs
Qooxdoo's AutoGenerated IDs [message #81076] Thu, 03 April 2008 00:23 Go to next message
Hi all,
I've recently read from
http://qooxdoo.org/documentation/contrib/simulator/qooxdoo-t ests-with-selenium,
that Qooxdoo developers has added capability to auto-generate IDs on their
widget, can I use this IDs instead the one provided by RAP to test our
application ?
Setya
Re: Qooxdoo's AutoGenerated IDs [message #81372 is a reply to message #81076] Fri, 04 April 2008 06:47 Go to previous messageGo to next message
As far as I can see you would need to compile qooxdoo again with these
options set. Therefor you'd need to build the RAP qooxdoo out of the
rap.tools project which is really not recommended.
I wonder why you want those ids instead of custom ideas brought to you
by RAP since some time.
Greets
Benny
Setya wrote:
> Hi all,
> their widget, can I use this IDs instead the one provided by RAP to test
> our application ?
> Regards,
> Setya
Re: Qooxdoo's AutoGenerated IDs [message #81401 is a reply to message #81372] Fri, 04 April 2008 08:41 Go to previous messageGo to next message
Benjamin,
Thanks for your explanation.
The ID generated by RAP is fine actually, but I have a little problem that
I've asked here :
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg02128.html
Best Regards,
Setya
Re: Qooxdoo's AutoGenerated IDs [message #81430 is a reply to message #81401] Fri, 04 April 2008 09:10 Go to previous messageGo to next message
Ok, the advantage of the Ids generated by RAP is that they refer to
widgets as you know them. So it refers to a composite, a tree widget or
a button.
If you'd use the qooxdoo ids you need to care about several things:
a) qooxdoo widgets have other names then swt widgets (they get mapped by is)
b) some swt widgets are created by composition of existing widgets. eg.
a swt tree = a qooxdoo layout with an inner tree.
This would make writing tests much more difficult.
The question you mentioned is hard to answer. But Ralf is true that it
could be the TextSizeDetermination which causes this inconsistency. I'm
not sure at the moment if we can do anything here. if this a real
blocker for you, open a bug. But I can't guarantee that we will fix this
or be able to fix it in a nice way.
Greets
Benny
Setya wrote:
> Benjamin,
> that I've asked here :
> Best Regards,
> Setya
Re: Qooxdoo's AutoGenerated IDs [message #81463 is a reply to message #81430] Fri, 04 April 2008 10:19 Go to previous message
Benny,
> a button.
Your explanation above sounds scary.
I was wondering if other RAP users ever have similliar problem with me or
maybe they have workaround on this ?
In Bugzilla we have Framework for Unit Tests request here :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154514
Does RAP team already have plan to address it ?
Best Regards,
Setya
Previous Topic:Drop Down Menu
Next Topic:Button issue
Current Time: Thu Sep 04 03:29:20 EDT 2025
Powered by FUDForum. Page generated in 0.05540 seconds
