Home » Modeling » EMF » [CDO]: NoClassDefFoundError: com/emfdbexample/orgstructure/model/modelPackage (wrong name: com/emfdb
[CDO]: NoClassDefFoundError: com/emfdbexample/orgstructure/model/modelPackage (wrong name: com/emfdb [message #813853] Mon, 05 March 2012 14:38 Go to next message
I am trying to learn using CDO by creating a litte example based on the
org.eclipse.emf.cdo.examples.company/com.eclipse.emf.cdo.examples.hibernate.server
- example projects.
When I run the QuickStartTest that I have adapted to my example project
it fails with the following trace:
org.eclipse.emf.cdo.util.CommitException:
org.eclipse.net4j.signal.RemoteException:
java.lang.NoClassDefFoundError: com/emfdbexample/orgstructure/model
/modelPackage (wrong name: com/emfdbexample/orgstructure/model/ModelPackage)
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1083)
The test case passes when I adjust in the properties of the genmodel the
All->prefix value from "Model" to "model" and regenerate the model code
(and correct the import problem due to the changed prefix).
What makes me wonder, is that the company example project also has
All->prefix value set to a value starting with a capital letter
"Company" and it works.
Is there a configuration that prevents the ClassNotFoundException in the
company-example projects?
Furthermore, could somebody give a hint, what configuration generates
the hibernate mapping file "generated_hbm.xml" in
com.eclipse.emf.cdo.examples.hibernate.server > META-INF.
Kris
Re: [CDO]: NoClassDefFoundError: com/emfdbexample/orgstructure/model/modelPackage (wrong name: com/e [message #814185 is a reply to message #813853] Tue, 06 March 2012 01:09 Go to previous messageGo to next message
Hi Kris,
Disclaimer: I'm neither a Hibernate nor a HibernateStore expert. I've cc'ed Martin.
More comments below...
Am 05.03.2012 20:38, schrieb KW:
> org.eclipse.emf.cdo.examples.company/com.eclipse.emf.cdo.examples.hibernate.server - example projects.
When I run it without modifications it passes successfully. Have you also tried that?
> org.eclipse.emf.cdo.util.CommitException: org.eclipse.net4j.signal.RemoteException: java.lang.NoClassDefFoundError:
> com/emfdbexample/orgstructure/model /modelPackage
Is there really a space after the second last segment?
I'm confused. What's wrong and what's right in your opinion?
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1083)
> The test case passes when I adjust in the properties of the genmodel the All->prefix value from "Model" to "model" and
> regenerate the model code (and correct the import problem due to the changed prefix).
> What makes me wonder, is that the company example project also has All->prefix value set to a value starting with a
> capital letter "Company" and it works.
> Is there a configuration that prevents the ClassNotFoundException in the company-example projects?
It strikes me that this is related to your modifications, which I can't judge. Please note that the plugin.xml of your
(example) model is not regenerated once it exists. Make sure the nsURI and Model Package classname match properly.
> Furthermore, could somebody give a hint, what configuration generates the hibernate mapping file "generated_hbm.xml"
> in com.eclipse.emf.cdo.examples.hibernate.server > META-INF.
Perhaps this page helps:
http://wiki.eclipse.org/CDO_Hibernate_Store_Model_Relational_Mapping#Generating_the_mapping.2C_manually_changing_it_and_then_use_the_manual_mapping
Cheers
/Eike
http://www.esc-net.de
Re: [CDO]: NoClassDefFoundError: com/emfdbexample/orgstructure/model/modelPackage (wrong name: com/e [message #814742 is a reply to message #814185] Tue, 06 March 2012 15:54 Go to previous message
Hi Eike,
thanks for your advice. Gefahr erkannt, Gefahr gebannt :)
it was the extension point that was outdated (modelPackage instead of
ModelPackage) in the plugin.xml of the model proeject:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri="http://orgstructure/1.0"
class="com.emfdbexample.orgstructure.model.modelPackage"
genModel="model/orgstructure.genmodel"/>
</extension>
Kris
Am 3/6/12 7:09 AM, schrieb Eike Stepper:
> Hi Kris,
> cc'ed Martin.
>> Hi,
>> the
>> - example projects.
> also tried that?
>> /modelPackage
>> at
>> the All->prefix value from "Model" to "model" and regenerate the model
> judge. Please note that the plugin.xml of your (example) model is not
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Previous Topic:org.eclipse.emf.ocl
Next Topic:[TENEO] Objects without container and in different resources are both saved
Current Time: Sat Jul 19 01:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.25169 seconds
