Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #811344] |
Fri, 02 March 2012 03:14  |
Hi all,
I have a RCP project: when I copied the helpdoc plugin jar to the dir "plugins" and run this application, I found new installed plugin are not included in the file configuration/org.eclipse.equinox.simpleconfigurator/bundles.info. So I can not see this help doc in the help content area of our RCP.
If I copied the plugin jar to a Standard Eclipse, then one line info about this plugin will be added to the file configuration/org.eclipse.equinox.simpleconfigurator/bundles.info and the help content can be shown correctly.
Does anyone know when and how the project detect the plugins automatically?
This is my configuration/config.ini:
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Tue Feb 21 14:11:59 GMT 2012
org.eclipse.update.reconcile=false
eclipse.p2.profile=profile
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar
equinox.use.ds=true
eclipse.product=myproject.product
osgi.splashPath=platform\:/base/plugins/myproject
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.nl1_3.6.2.v201102251823.jar,reference\:file\:org.eclipse.osgi.nl2_3.6.2.v201102251823.jar,reference\:file\:org.eclipse.osgi.nlBidi_3.6.2.v201102251823.jar
osgi.bundles.defaultStartLevel=4
eclipse.p2.data.area=@config.dir/../p2
eclipse.application=myproject.application
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start,reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
Hart
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #823903 is a reply to message #814949] |
Sun, 18 March 2012 22:31  |
Hi all,
Finally I found the root cause, I must start the p2 service to scan the plugins dir, the below snippet should be added to the .product file.
<configurations>
<plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="4" />
<plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.equinox.p2.reconciler.dropins" autoStart="true" startLevel="5" />
<plugin id="org.eclipse.equinox.simpleconfigurator" autoStart="true" startLevel="1" />
</configurations>
Thanks.
FUDForum. Page generated in 0.06867 seconds
