Home » Archived » BIRT » BIRT Excel export, Office 2007, warning(The file you are trying to open, 'name.ext', is in a different format than specified by the file extension.)
BIRT Excel export, Office 2007, warning [message #548367] Wed, 21 July 2010 11:08 Go to next message
opening my BIRT excel report with Office 2007 causes warning:
The file you are trying to open, 'name.ext', is in a different format than specified by the file extension. Verify that the file is not corrupted and is from a trusted source before opening the file. Do you want to open the file now?
How can I avoid this warning?
I'm using:
BIRT 2.5.2
Office 2007
Eclipse Build: 20100218-1602
Reinhard
Re: BIRT Excel export, Office 2007, warning [message #548674 is a reply to message #548367] Thu, 22 July 2010 11:41 Go to previous messageGo to next message
Reinhard,
Are you running the XLS directly from the designer or are you first
viewing it in the viewer and then exporting to xls?
Jason
On 7/21/2010 11:08 AM, Reinhard wrote:
> Hello,
> I'm using:
> BIRT 2.5.2
> Office 2007
> Regards
> Reinhard
Re: BIRT Excel export, Office 2007, warning [message #549170 is a reply to message #548367] Sun, 25 July 2010 14:19 Go to previous messageGo to next message
I always get that warning and you can ignore it. The default Excel emitter doesn't write binary-format Excel files, it writes an interchange format that Microsoft publishes. Excel recognizes the file type when it parses the input but complains that it should have a different extension so it won't have to change gears. I don't know what the extension Microsoft expects is.
Re: BIRT Excel export, Office 2007, warning [message #549215 is a reply to message #548674] Mon, 26 July 2010 03:19 Go to previous messageGo to next message
I generate excel reports programmatically and export them in a file, so I don't open it from viewer or designer.
Here some code snippets:
HTMLRenderOption option = new HTMLRenderOption();
OutputStream outputStream = new FileOutputStream(new File("C:\", "report.xls"));
option.setOutputStream(outputStream);
option.setOutputFormat("xls");
runAndRenderTask.setRenderOption(option);
runAndRenderTask.run();
@Richard
Yes, I know that I can ignore that, but not my customer and it is very irritating to click on "Yes" opening every report
Re: BIRT Excel export, Office 2007, warning [message #549217 is a reply to message #549170] Mon, 26 July 2010 03:21 Go to previous messageGo to next message
Excel expects the extension xlsx, docx or pptx. When you save your
preview as file and change the extension, the warning in excel should
not occur anymore...
Re: BIRT Excel export, Office 2007, warning [message #549218 is a reply to message #549217] Mon, 26 July 2010 03:22 Go to previous messageGo to next message
Obviously I meant "Office expects..." and not Excel ;-)
Re: BIRT Excel export, Office 2007, warning [message #549846 is a reply to message #549218] Wed, 28 July 2010 04:27 Go to previous messageGo to next message
Changing the filie extension to .xlsx doesn't solve my problem. More than that. I even can't open the file. Excel brings this error message: "The file "report.xlsx" cannot be open by Excel, because the file format and the file extension is invalid. Check if file is damaged and if file extension answers to file format.
If I use .xml as extension for my report and open it with Excel everything works fine without errors or warnings, but that will confuse my customer.
Re: BIRT Excel export, Office 2007, warning [message #551937 is a reply to message #549846] Tue, 10 August 2010 04:59 Go to previous messageGo to next message
Any other ideas or solutions on that?
Re: BIRT Excel export, Office 2007, warning [message #552032 is a reply to message #551937] Tue, 10 August 2010 11:06 Go to previous messageGo to next message
Have you logged a bug for this?
Jason
Re: BIRT Excel export, Office 2007, warning [message #556845 is a reply to message #548367] Thu, 02 September 2010 15:21 Go to previous messageGo to next message
Hi Jason,
I run into the exact issue on Birt 2.5.2. Is there a fix for this issue?
kenny
Re: BIRT Excel export, Office 2007, warning [message #556858 is a reply to message #556845] Thu, 02 September 2010 15:49 Go to previous messageGo to next message
Take a look at this bugs:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=267988
Jason
On 9/2/2010 3:21 PM, dash wrote:
> Hi Jason,
> kenny
Re: BIRT Excel export, Office 2007, warning [message #778364 is a reply to message #548367] Thu, 12 January 2012 10:54 Go to previous messageGo to next message
I know this is an old thread. But does anyone have solution for this issue?
Re: BIRT Excel export, Office 2007, warning [message #811697 is a reply to message #778364] Fri, 02 March 2012 12:56 Go to previous messageGo to next message
I have the same annoying problem . Have anyone solved the issue ?
Re: BIRT Excel export, Office 2007, warning [message #813294 is a reply to message #811697] Sun, 04 March 2012 23:19 Go to previous message
We had the same issue. BIRT generated excels are not native excels. Try using Tribix or Native excel emitters. We are using that right now
http://sourceforge.net/projects/tribix/
http://code.google.com/a/eclipselabs.org/p/native-excel-emitter-birt-plugin/
[Updated on: Sun, 04 March 2012 23:21] by Moderator
Previous Topic:Localization of DataSet Field
Next Topic:GetXMLParams
Current Time: Thu Jul 24 22:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.06369 seconds
