Best way to extend Xtend? [message #812958] |
Sun, 04 March 2012 11:19  |
I'm trying to extend Xtend (!) with a new XPrimaryExpression. My first attempt was to create a new XText grammar like this:
grammar com.ibm.mwc.xtext.Coava with org.eclipse.xtext.xtend2.Xtend2
and then to override the XPrimaryExpression defined in XBase, something like this:
XPrimaryExpression returns XExpression:
XConstructorCall |
XBlockExpression |
XSwitchExpression |
XFeatureCall |
XLiteral |
XIfExpression |
XForLoopExpression |
XWhileExpression |
XDoWhileExpression |
XThrowExpression |
XReturnExpression |
XTryCatchFinallyExpression |
XParenthesizedExpression |
XMyNewExpression;
The main reason it does not work is XExpression is sealed.
So my question is what is the recommended way to create a grammar based on XTend2?
Lionel
Re: Best way to extend Xtend? [message #976805 is a reply to message #976730] |
Thu, 08 November 2012 16:37   |
Hi Iuzuz,
it might be that the generated package is wrong. The
XtendProposalProvider is in xtend.ide.contentassist and not in core.ui..
I'm afraid you'll have to adapt that manually
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 08.11.12 21:28, schrieb Iuzuz Denker:
> Hello Xtend-frieds,
> I also want to extend Xtend and try out some ideas. But some things has
> been changed since last message (at least the URLs) and the guidance
> seems not to work any more. I must say I am an Xtext beginner.
> Steps, I tried:
> Installed a new Eclipse with Xtext
> Created a new Xtext project (=4 projects)
> Changed the with-clause to "with org.eclipse.xtend.core.Xtend" -> can't
> resolve the grammar
> Added to the project org.xtext.example.mydsl a manifest dependence to
> ...xtend.core -> the error disappear
> added to the .mwe2 file:
> registerGeneratedEPackage = "org.eclipse.xtend.core.xtend.XtendPackage"
> registerGenModelFile =
> "platform:/resource/org.eclipse.xtend.core/model/Xtend.genmodel"
> "Generate Xtext Artifacts" (on the .xtext file) -> Successful (with the
> download)
> After the (successful) generating there is a compile error in th ..ui
> project:
> Quote:
>> The project was not built since its build path is incomplete. Cannot
>> find the class file for
>> org.eclipse.xtend.core.services.XtendGrammarAccess$ImportElements. Fix
>> the build path then try building this project
> Added to the project org.xtext.example.mydsl a manifest dependences to
> all ..xtend.. and ..xbase.. (without .source)
> I get 6 erroros, the base seems to be, the package
> org.eclipse.xtend.core.ui and the class are not in the classpath
> org.eclipse.xtend.core.ui.contentassist.XtendProposalProvider
> But if I ctrl-click on it, it is found in one of the dependences.
> Have any one a suggestion?
> What do I make wrong?
> Thanks, Iuzuz
Re: Best way to extend Xtend? [message #977872 is a reply to message #976805] |
Fri, 09 November 2012 11:53  |
Thank you Sebastian,
it helps.
But after generating artifacts again, the problem is again there.
As a workaround I created a class in ...ui/src:
package org.eclipse.xtend.core.ui.contentassist;
public class XtendProposalProvider
extends org.eclipse.xtend.ide.contentassist.XtendProposalProvider {}
Thank you again.
FUDForum. Page generated in 0.07634 seconds
