Home » Archived » BIRT » complex pivot table(how to create complex pivot table with cross tabs)
complex pivot table [message #812837] Sun, 04 March 2012 06:39 Go to next message
i need to create this table in birt.
the date should by dimanic.
i am trying to use cross tabs but it doesnt give me the wanted functionality.
student name| mathematics | science
01/01/2010|02/01/2010|03/01/2010| 01/01/2010|02/01/2010|03/01/2010| stud1 82 83 84 52 52 53
stude2 52 52 98 65 67 52 the values of the months should be hiden , just the deviation of the grades should exist.
my data set is:
date | student | mathemathics| science
can you please help me to understans how it can be implemented?
Re: complex pivot table [message #813936 is a reply to message #812837] Mon, 05 March 2012 16:34 Go to previous messageGo to next message
Can you put some sample data in a text file to create a report off of?
If so post it and the desired output. For example you have dates, do
you want the years shown only?
Jason
On 3/4/2012 6:39 AM, marina tzerluk wrote:
> Hi
> functionality.
> my data set is:
Re: complex pivot table [message #814494 is a reply to message #813936] Tue, 06 March 2012 09:12 Go to previous message
hi
i have two flat files .dinamic2, dinamic3.
basiclly my original file looks like dinamic2, but i figure out some solution for my problem, where i duplicate 2 columns(type which is performance or availablity) and value (the original vLUE FOR PERFORMANCE/AVAILABILITY). i can creat those computed columns in the run time in birt as well.
but this solution is not good enough because it means i need to duplicate all data to performance and availability.
i tried taking different approach like the one in my second table, but in this case i cant add some additional columns like volums...
if you can give me some better solution it would be great.
Previous Topic:birt report java script problem in chrome and firefox
Next Topic:How to dynamically remove or disable a chart (or other element)?
Current Time: Sat Jul 26 19:19:45 EDT 2025
Powered by FUDForum. Page generated in 0.03203 seconds
