Home » Eclipse Projects » Rich Client Platform (RCP) » Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins
Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #811344] Fri, 02 March 2012 03:14 Go to next message
Hi all,
I have a RCP project: when I copied the helpdoc plugin jar to the dir "plugins" and run this application, I found new installed plugin are not included in the file configuration/org.eclipse.equinox.simpleconfigurator/bundles.info. So I can not see this help doc in the help content area of our RCP.
If I copied the plugin jar to a Standard Eclipse, then one line info about this plugin will be added to the file configuration/org.eclipse.equinox.simpleconfigurator/bundles.info and the help content can be shown correctly.
Does anyone know when and how the project detect the plugins automatically?
This is my configuration/config.ini:
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Tue Feb 21 14:11:59 GMT 2012
org.eclipse.update.reconcile=false
eclipse.p2.profile=profile
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar
equinox.use.ds=true
eclipse.product=myproject.product
osgi.splashPath=platform\:/base/plugins/myproject
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.nl1_3.6.2.v201102251823.jar,reference\:file\:org.eclipse.osgi.nl2_3.6.2.v201102251823.jar,reference\:file\:org.eclipse.osgi.nlBidi_3.6.2.v201102251823.jar
osgi.bundles.defaultStartLevel=4
eclipse.p2.data.area=@config.dir/../p2
eclipse.application=myproject.application
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start,reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
Hart
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #811520 is a reply to message #811344] Fri, 02 March 2012 08:06 Go to previous messageGo to next message
The installation is now managed with a tool called p2; save yourself from grief and do *not* try to modify any of these files by hand!
If you want to add a single bundle, you can add it to the "dropins" folder. Providing you have the p2 dropins reconciler in your app, it will be picked up on restart.
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #812647 is a reply to message #811520] Sat, 03 March 2012 23:34 Go to previous messageGo to next message
Hi Brian,
Thanks for providing this help info.
Yes, I have added p2 function to my project, and can add a new plugin from the repository(remote site or local archive) in my RCP. But I can not import the help doc from local archive as RCP reports "No software site found in my plugins". The questions is I can add this jar file to a Standard Eclipse3.6.2 by putting this jar to plugin folder, but does not work in my RCP.
When I export the RCP, then I find the folder "p2" but can not find the folder "dropins" in the exported project. And when I add a folder "dropins" in my RCP manually and provide one plugin to my app, seems it will not be picked up on restart.
Did I miss some steps when exporting, so there is no dropins folder in my exported RCP. OR I missed some p2 plugins in my app? My plugins in feature.xml is as below:
org.eclipse.equinox.p2.artifact.repository
org.eclipse.equinox.p2.artifact.repository.nl1"
org.eclipse.equinox.p2.artifact.repository.nl2"
org.eclipse.equinox.p2.artifact.repository.nlBidi"
org.eclipse.equinox.p2.core"
org.eclipse.equinox.p2.core.nl1"
org.eclipse.equinox.p2.core.nl2"
org.eclipse.equinox.p2.core.nlBidi"
org.eclipse.equinox.p2.jarprocessor"
org.eclipse.equinox.p2.jarprocessor.nl1"
org.eclipse.equinox.p2.jarprocessor.nl2"
org.eclipse.equinox.p2.jarprocessor.nlBidi"
org.eclipse.equinox.p2.metadata"
org.eclipse.equinox.p2.metadata.generator"
org.eclipse.equinox.p2.metadata.generator.nl1"
org.eclipse.equinox.p2.metadata.generator.nl2"
org.eclipse.equinox.p2.metadata.generator.nlBidi"
org.eclipse.equinox.p2.metadata.nl1"
org.eclipse.equinox.p2.metadata.nl2"
org.eclipse.equinox.p2.metadata.nlBidi"
org.eclipse.equinox.p2.metadata.repository"
org.eclipse.equinox.p2.metadata.repository.nl1"
org.eclipse.equinox.p2.metadata.repository.nl2"
org.eclipse.equinox.p2.metadata.repository.nlBidi"
org.eclipse.equinox.p2.console.nl1"
org.eclipse.equinox.p2.console.nl2"
org.eclipse.equinox.p2.console.nlBidi"
org.eclipse.equinox.p2.director"
org.eclipse.equinox.p2.director.app"
org.eclipse.equinox.p2.director.app.nl1"
org.eclipse.equinox.p2.director.app.nl2"
org.eclipse.equinox.p2.director.app.nlBidi"
org.eclipse.equinox.p2.director.nl1"
org.eclipse.equinox.p2.director.nl2"
org.eclipse.equinox.p2.director.nlBidi"
org.eclipse.equinox.p2.directorywatcher"
org.eclipse.equinox.p2.directorywatcher.nl1"
org.eclipse.equinox.p2.directorywatcher.nl2"
org.eclipse.equinox.p2.directorywatcher.nlBidi"
org.eclipse.equinox.p2.engine"
org.eclipse.equinox.p2.engine.nl1"
org.eclipse.equinox.p2.engine.nl2"
org.eclipse.equinox.p2.engine.nlBidi"
org.eclipse.equinox.p2.extensionlocation"
org.eclipse.equinox.p2.extensionlocation.nl1"
org.eclipse.equinox.p2.extensionlocation.nl2"
org.eclipse.equinox.p2.extensionlocation.nlBidi"
org.eclipse.equinox.p2.garbagecollector"
org.eclipse.equinox.p2.garbagecollector.nl1"
org.eclipse.equinox.p2.garbagecollector.nl2"
org.eclipse.equinox.p2.garbagecollector.nlBidi"
org.eclipse.equinox.p2.reconciler.dropins"
org.eclipse.equinox.p2.reconciler.dropins.nl1"
org.eclipse.equinox.p2.reconciler.dropins.nl2"
org.eclipse.equinox.p2.reconciler.dropins.nlBidi"
org.eclipse.equinox.p2.touchpoint.eclipse"
org.eclipse.equinox.p2.touchpoint.eclipse.nl1"
org.eclipse.equinox.p2.touchpoint.eclipse.nl2"
org.eclipse.equinox.p2.touchpoint.eclipse.nlBidi"
org.eclipse.equinox.p2.touchpoint.natives"
org.eclipse.equinox.p2.touchpoint.natives.nl1"
org.eclipse.equinox.p2.touchpoint.natives.nl2"
org.eclipse.equinox.p2.touchpoint.natives.nlBidi"
org.eclipse.equinox.p2.ui"
org.eclipse.equinox.p2.ui.nl1"
org.eclipse.equinox.p2.ui.nl2"
org.eclipse.equinox.p2.ui.nlBidi"
org.eclipse.equinox.p2.ui.sdk"
org.eclipse.equinox.p2.ui.sdk.nl1"
org.eclipse.equinox.p2.ui.sdk.nl2"
org.eclipse.equinox.p2.ui.sdk.nlBidi"
org.eclipse.equinox.p2.updatechecker"
org.eclipse.equinox.p2.updatechecker.nl1"
org.eclipse.equinox.p2.updatechecker.nl2"
org.eclipse.equinox.p2.updatechecker.nlBidi"
org.eclipse.equinox.p2.updatesite"
org.eclipse.equinox.p2.updatesite.nl1"
org.eclipse.equinox.p2.updatesite.nl2"
org.eclipse.equinox.p2.updatesite.nlBidi"
Thank you very much!
Hart
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #812652 is a reply to message #812647] Sat, 03 March 2012 23:44 Go to previous messageGo to next message
Brian,
Do you have any good guide/article to introduce how to add P2 to my applications?
Hart
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #813944 is a reply to message #812652] Mon, 05 March 2012 16:48 Go to previous messageGo to next message
I'd start with http://wiki.eclipse.org/Equinox/p2/Adding_Self-Update_to_an_RCP_Application which must include p2 to use the update functionality.
PW
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #814949 is a reply to message #813944] Tue, 06 March 2012 22:23 Go to previous messageGo to next message
Thanks Paul.
Yes, I have configured as this guide before. And I can install a new plugin using the "Install new software".
My question here is whether a RCP using p2 still support to install a plugin by putting the jar file to dir Plugins of RCP directly? As the jar file can not be installed by "Install new software" as RCP reports "No software site found in this plugins". But this plugin can be shown in the earlier version of RCP which does not use P2 by putting it to the plugins folder directly.
Hart
Re: Why org.eclipse.equinox.simpleconfigurator/bundles.info can not be updated based on the plugins [message #823903 is a reply to message #814949] Sun, 18 March 2012 22:31 Go to previous message
Hi all,
Finally I found the root cause, I must start the p2 service to scan the plugins dir, the below snippet should be added to the .product file.
<configurations>
<plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="4" />
<plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.equinox.p2.reconciler.dropins" autoStart="true" startLevel="5" />
<plugin id="org.eclipse.equinox.simpleconfigurator" autoStart="true" startLevel="1" />
</configurations>
Thanks.
Previous Topic:How to create an auto-extendable RCP product?
Next Topic:Control based authorization in eclipse RCP
Current Time: Sun Jul 27 15:25:35 EDT 2025
Powered by FUDForum. Page generated in 0.25733 seconds
