Home » Eclipse Projects » GEF » understanding connection invalidation
understanding connection invalidation [message #81212] Tue, 27 May 2003 17:52 Go to next message
I had a scenario that worked, and then I changed it and it doesn't
work
Here is the scenario that worked
Parent object with FlowLayout
Editpart A with FlowLayout
child EditPart B with FlowLayout
children of EditPart B have Connections between them
If I insert a part before A, everything works as expected:
- A moves over on the screen
- B moves over
- children of B move over
- connections in children move over.
Now:
I changed child EditPart B to have a FreeFormLayer and XYLayout (I had
to override FreeFormLayer to use LocalCoordinates) so that the
children can be manually placed.
Now if I insert a part before A, everything but the connections inside
B moves over.
The connectionparts in the first scenario get invalidated and
re-layout but this doesn't happen anymore in B.
How do I force the connections to reLayout in the second case?
thanks
Ray
Re: understanding connection invalidation [message #81241 is a reply to message #81212] Wed, 28 May 2003 00:36 Go to previous messageGo to next message
Freeform figures cannot be translated or have their bounds set. By
definition, they shrink-wrap their bounds to the smallest Rectangle that
will contain their children (and the point 0,0). Will just a plain figure
in XYLayout work in this case?
Freeform figures are only intended to be placed inside FreeformViewports,
since that is the only way in which they can expand into the negative X and
Y coordinates anyway.
"Ray Tsui" <Raymond_Tsui@ca.ibm.com> wrote in message
news:nvm7dvsd8ngi2p9o7v6kc74uuohiir8udi@4ax.com...
> work
> - B moves over
> Now:
> B moves over.
> thanks
> Ray
Re: understanding connection invalidation [message #81268 is a reply to message #81241] Wed, 28 May 2003 01:15 Go to previous messageGo to next message
You probably can call setBounds(), but the children will not get translated
as a result of doing so. This is by design, since setting the bounds comes
after the children are layed out.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bb1edb$5ge$1@rogue.oti.com...
and
> > work
> > - B moves over
> > Now:
> > B moves over.
> > thanks
> > Ray
Re: understanding connection invalidation [message #81326 is a reply to message #81268] Wed, 28 May 2003 09:15 Go to previous messageGo to next message
It seems to me that the freeformlayer "breaks" the notification chain
by overriding FireMoved(). Normally, it seems that the figures pass on
this notification to allow the connections to lay out themselves, but
I guess since the Freeformlayer is not normally placed inside a
Flowlayout, this was intentional.
I can get it to work by cloning the Freeformlayer class and removing
the override. I don't know if this is a bad approach though.
thanks
Ray
On Wed, 28 May 2003 01:15:45 -0400, "Randy Hudson" <none@us.ibm.com>
Re: understanding connection invalidation [message #81355 is a reply to message #81326] Wed, 28 May 2003 10:32 Go to previous messageGo to next message
If you are really useing the Freeform layer as intended, then restoring the
notification may cause an infinite loop. Why do you need a FreeFormLayer?
Have you placed it inside a ScrollPane figure?
news:jfc9dvgo83a51kajq3du5r59k7t7jmjmq1@4ax.com...
The FreeformLayer never moves. Only its children move. Firing figure moved
is used in two ways. It may indicate that the figure itself moved. But it
is also used to indicate that the coordinate system in which the children
"live" has changed. AncestorListeners, such as connection anchors, are
interested in whether their source figure, or *any* of its ancestors move or
otherwise change the absolute coordinate of the connection anchor.
> thanks
> Ray
translated
comes
Re: understanding connection invalidation [message #81410 is a reply to message #81355] Wed, 28 May 2003 10:56 Go to previous messageGo to next message
Maybe you can suggest the proper approach?
I have an contaner editpart (I call XYContainer) which contains other
objects with x,y relative coordiantes and connections. This container
can be inside other editparts with FlowLayouts or itself be contained
inside XYContainer.
What kind of figure and layout would you suggest I use? The
XYContainer should automatically grow to enclose all its XY children,
but move all its contents automatically when its parent FlowLayout
causes it to move.
Ray
On Wed, 28 May 2003 10:32:57 -0400, "Randy Hudson" <none@us.ibm.com>
>> thanks
>> Ray
>translated
>comes
Re: understanding connection invalidation [message #81439 is a reply to message #81410] Wed, 28 May 2003 14:56 Go to previous message
news:d4j9dvcp7l5obpdtjinvs2s4bgt9rofu3o@4ax.com...
> inside XYContainer.
> causes it to move.
A Figure in XYLayout will do this.
> Ray
the
FreeFormLayer?
moved
it
or
> >> thanks
> >> Ray
> >translated
> >comes
Previous Topic:Show tooltip for handle
Next Topic:Connection creation
Current Time: Sat Jul 19 00:34:07 EDT 2025
Powered by FUDForum. Page generated in 0.07509 seconds
