Home » Eclipse Projects » Eclipse 4 » Event handler not called (button)
Event handler not called (button) [message #809466] Tue, 28 February 2012 17:51 Go to next message
When I start a clean application and create an MPart from an MPartDescriptor and show it, it automatically receives the focus. When I click on a button in the MPart for the first time, the event is fired and the event handler is called. This is the expected behaviour.
When I close this application without deleting the MPart and start it again, the MPart is immediately created from the model state that has been saved before. This time MPart does not immediately receive the focus. This is o.k., since there might be more than one MPart. If I now click on the same button again for the first time, the MPart receives the focus (o.k.), but the event is not fired, i.e. the handler of the button is not called. It is only called, when I click for the second time on the button.
To summarize: The handler of a button is only called, when the corresponding MPart had the focus before the button is clicked. Otherwise one has to click the button twice, to get the handler called once, which is completely unexpected.
Have I missed something, or is this a bug in e4 (Version: 4.2.0 / Build id: I20120209-1230)?
Re: Event handler not called (button) [message #810641 is a reply to message #809466] Thu, 01 March 2012 06:10 Go to previous messageGo to next message
Can you paste a simple version of the Part code, so that we can have a look?
Re: Event handler not called (button) [message #811621 is a reply to message #810641] Fri, 02 March 2012 11:01 Go to previous messageGo to next message
Lars Vogel wrote on Thu, 01 March 2012 12:10
package de.gps.log.db.ui.views;
import javax.annotation.PostConstruct;
import javax.annotation.PreDestroy;
import javax.inject.Inject;
import org.eclipse.e4.ui.di.Focus;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
public class LogView {
	public static String ID = "de.gps.log.db.ui.LogView";
	private final Composite parent;
	// e4 will inject the composite "parent" into the view
	@Inject
	public LogView(Composite parent) {
		// the following is standard SWT Stuff
		this.parent = parent;
	@Focus
	void setFocus() {
		System.out.println("DBLogView -- setFocus");
	// PostConstruct ensures that the dependency injection has been finished
	// when this method is called
	@PostConstruct
	public void buildUI() {
		System.out.println("DBLogView -- buildUI");
		Composite composite = new Composite(parent, SWT.NONE);
		GridLayout layout = new GridLayout();
		layout.horizontalSpacing = 0;
		layout.verticalSpacing = 0;
		layout.marginWidth = 0;
		layout.marginHeight = 0;
		composite.setLayout(layout);
		composite.setLayoutData(new GridData(GridData.FILL_BOTH));
		createViewer(composite);
	@PreDestroy
	public void dispose() {
		// this is necessary
		System.out.println("DBLogView -- dispose");
	private void createViewer(Composite parent) {
		Button button = new Button(parent, SWT.NONE);
		button.addSelectionListener(new SelectionListener(){
			public void widgetSelected(SelectionEvent e) {
				System.out.println("Button pressed");
			public void widgetDefaultSelected(SelectionEvent e) {
It doesn't look nice, but it is sufficient to reproduce the problem -- or find my mistake.
Re: Event handler not called (button) [message #811976 is a reply to message #811621] Fri, 02 March 2012 22:08 Go to previous messageGo to next message
Your @Focus should be setting focus to the inner composite.
Re: Event handler not called (button) [message #812141 is a reply to message #811976] Sat, 03 March 2012 04:24 Go to previous messageGo to next message
Brian de Alwis wrote on Sat, 03 March 2012 04:08
Which composite do you mean? I cannot set the focus on the "private final Composite parent", since this will result in the exception "Blocked recursive attempt to activate part".
Making the composite created in buildUI(), which has "private final Composite parent" as parent, a global variable and setting the focus on this composite does not change anything, i.e. the problem remains.
Re: Event handler not called (button) [message #812246 is a reply to message #812141] Sat, 03 March 2012 08:25 Go to previous messageGo to next message
Ok, the hint with a missing setFocus was basically correct. The following line of code fixes the problem:
composite.setFocus();
However, this line of code has to be added as last line of the method buildUI().
When the MPart is created in the handler using the code
	@Execute
	public void execute(EPartService partService) {
		MPart part = partService.findPart(LogView.ID);
		if (part == null) {
			part = partService.createPart(LogView.ID);
		if (part != null) {
			part.setLabel("DBLogView");
			part.setTooltip("Tooltip");
			partService.showPart(part, PartState.ACTIVATE);
then partService.showPart(...) ensures, that the @Focus method is called immediately. Even more, everything works properly without explicitly calling composite.setFocus() at all. I.e. it must neither be called in buildUI() nor in the @Focus method.
If the UI is built after the application restarts, the Part is shown but the @Focus method is not called immediately. Although the Part is completely visible, the @Focus method is only called when I first click into the part. However, for the part to work properly in this case, composite.setFocus() has to be called explicitly in buildUI().
If, on the other hand, composite.setFocus() is called in buildUI(), then in certain cases this method is called twice.
This behaviour should be a bug.
Re: Event handler not called (button) [message #813698 is a reply to message #812246] Mon, 05 March 2012 11:11 Go to previous messageGo to next message
Hi Karl,
I'm not sure if I understand your example. Can you check if the following work:
private Button button;
@Inject
@Focus
public void setFocus() {
button.setFocus();
@PostConstruct
@PreDestroy
button.setText("Focus lost");
button.addSelectionListener(new SelectionListener() {
Best regards, Lars
Re: Event handler not called (button) [message #814412 is a reply to message #813698] Tue, 06 March 2012 07:17 Go to previous message
Hi Lars,
thanks, I will try when I am at home. But I think the underlying problem is, that the "restarted" part does not get the focus in time, or, to be more precise, I suspect that the following bug is the cause of my trouble. After I added my comment it was rescheduled from 4.1.2 to 4.2, so there seems to be hope that it might be fixed soon....
Previous Topic:Perspective switcher and other stuff in the window borders
Next Topic:PartSashContainer: cascading delete
Current Time: Sat Jul 26 21:26:20 EDT 2025
Powered by FUDForum. Page generated in 0.16796 seconds
