Home » Eclipse Projects » Remote Application Platform (RAP) » Close shell from within browser widget
Close shell from within browser widget [message #811533] Fri, 02 March 2012 08:27 Go to next message
In my RAP application I have a shell that only has one browser widget (full screen) as its content. Although the user has the possiblity to close this shell with the [x] button at the upper right corner, I like to automatically close the window after the work is done or offer the user a close button in the browser.
I cannot find a way to do this, so is this possible and if yes how?
Regards Bertin
Re: Close shell from within browser widget [message #811668 is a reply to message #811533] Fri, 02 March 2012 12:05 Go to previous messageGo to next message
Hi Bertin
Sure you can close a shell automatically and also with a close button.
Here the code snippet for a simple button:
Button close = new Button(shell, SWT.CENTER | SWT.PUSH);
close.setText("Close");
close.addSelectionListener(new SelectionAdapter() {
private static final long serialVersionUID = 1L;
public void widgetSelected(SelectionEvent e) {
shell.close();
With this snippet I'm sure you're also able to write your work-method which closes the shell automatically.
But as soon as Eclipse 3.8 is live you'll be able to start your Eclipse Scout App as RAP-Application out of the box ;)
Greetings Stephan
Re: Close shell from within browser widget [message #811694 is a reply to message #811533] Fri, 02 March 2012 12:47 Go to previous messageGo to next message
Hi.
If i understand your scenario correctly, what you want might be possible
using the BrowserFunction class. That allows you to call Java (RAP
application) from JavaScript (browser widget).
Greetings,
Tim
Re: Close shell from within browser widget [message #813001 is a reply to message #811694] Sun, 04 March 2012 12:45 Go to previous messageGo to next message
I tried using the browser function but I always get an error when closing the shell that created the browser and browserfunction.
public class OddOneOut extends Shell {
	private Browser b;
	private OddOneOutOefening oefening;
	public OddOneOut(final Shell parent, final int style, OddOneOutOefening o) {
		super(parent, style);
		setLayout(new FillLayout());
		setMaximized(true);
		this.oefening = o;
		b = new Browser(this, SWT.None);
		String url = "./resource/oddoneout.html";
		new CloseWindow(b, "closeWindow");
		b.setUrl(url);
	class CloseWindow extends BrowserFunction {
		CloseWindow(Browser browser, String name) {
			super(browser, name);
		public Object function(Object[] arguments) {
			try{
				System.out.println("Close Window just called from the browser");
				OddOneOut.this.close();
			catch(Exception ex){
				System.out.println("CloseWindow");
			return arguments;
So when I remove the line "OddOneOut.this.close();" everything works fine, but with this line enabled I get the error:
org.eclipse.swt.SWTError: Unknown error
	at org.eclipse.swt.SWT.error(SWT.java:3567)
	at org.eclipse.swt.SWT.error(SWT.java:3458)
	at org.eclipse.swt.SWT.error(SWT.java:3429)
	at org.eclipse.swt.browser.BrowserFunction.getName(BrowserFunction.java:185)
	at org.eclipse.swt.internal.browser.browserkit.BrowserLCA$2.run(BrowserLCA.java:282)
	at org.eclipse.rwt.lifecycle.ProcessActionRunner.executeNext(ProcessActionRunner.java:57)
	at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1132)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1124)
	at nl.rid.gramma.Application.createUI(Application.java:23)
	at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:73)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:211)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:88)
	at java.lang.Thread.run(Thread.java:662)
	at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
I don't think it is strange getting an error because the window is closed by the browser function. Maybe there is some other trick to make it work?
Regards Bertin
Re: Close shell from within browser widget [message #813497 is a reply to message #813001] Mon, 05 March 2012 05:38 Go to previous message
Seems the BrowserFunction is disposed while its still running. (Because
the shell is disposed.) It might work if you use Display#asyncExec to
close the shell, but I'm not sure. If it doesnt work, try if it works in
SWT (with and without asyncExec). If it does work in SWT, you can open a
bug in the RAP bugzilla.
Am 04.03.2012 18:45, schrieb Bertin Kiekebosch:
> private Browser b;
> o) {
> setMaximized(true);
> this.oefening = o;
> b.setUrl(url);
> try{
> return arguments;
> at
> at
> at
> at
> at
> at
> it work?
> Regards Bertin
Previous Topic:Rap on Mobile Platforms
Next Topic:Close shell from within browser widget
Current Time: Sat Jul 26 18:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.08856 seconds
