Home » Archived » EGL Development Tools » How do I know if a GET succeeded in fetching the record?
How do I know if a GET succeeded in fetching the record? [message #811661] Fri, 02 March 2012 12:04 Go to next message
I'm posting some code to make my point, but it's really a more general question.
function fetchSomeField(someOtherRecordID bigInt) returns (Timestamp?)
  someRecord1 SOMERECORD;
  get someRecord1 from ds using (someOtherRecordID) with #sql{
    select * from someTable where OTHERRECORD_ID = ?
  if (someRecord1 != null) <-- Fails, it's not null, even though such record doesn't exist
    return (someRecord1.timestampField1);
  else
    return (null);
  end
end
How do I know if the GET action did actually fetch a record or not?
Re: How do I know if a GET succeeded in fetching the record? [message #811740 is a reply to message #811661] Fri, 02 March 2012 14:18 Go to previous messageGo to next message
In the meanwhile, I'm using this:
  rs SQLResultSet?;
  open rs from ds using(someOtherRecordID) with #sql{
  if (rs.setNext())
    get someRecord1 from rs;
  else
    return (null);
  end
end
It looks quite right actually! Smile
Re: How do I know if a GET succeeded in fetching the record? [message #812398 is a reply to message #811661] Sat, 03 March 2012 14:04 Go to previous messageGo to next message
The first code you wrote was almost correct. You are checking someRecord1 for null, but you did not define it as nullable. Without a ? the initial value is an empty record and you can't even assign null to it.
should be:
someRecord1 SOMERECORD?;
Adding the ? to the declaration sets someRecord1's initial value to null. If no record is returned from the get it will remain null.
The second example accomplishes the same thing.
regards,
Joe
Re: How do I know if a GET succeeded in fetching the record? [message #813815 is a reply to message #812398] Mon, 05 March 2012 13:39 Go to previous message
I forgot about nullable semantics. Thanks, Joe!
Previous Topic:EGL EDT V 0.8.0 M2
Next Topic:selectionListeners
Current Time: Sun Jul 27 11:50:17 EDT 2025
Powered by FUDForum. Page generated in 0.04255 seconds
