Home » Eclipse Projects » GEF » ComboBoxPropertyDescriptor
ComboBoxPropertyDescriptor [message #80977] Tue, 27 May 2003 04:05 Go to next message
I'm trying to use the ComboBoxPropertyDescriptor in my implementation.
The coding is straight forward:
String[] types = {"XOR", "AND"};
ComboBoxPropertyDescriptor descr = new
ComboBoxPropertyDescriptor("stringvalue", "stringvalue", types);
return...;
When I open the properties tab in my workbench everything is OK. I select an
editpart and the
properties for that part are shown as they should. Now, I click on the
combobox descriptor to
change value from XOR to AND. What happens is that I get an
AssertionFailedException!!??
I have checked the Logic example and the code is almost the same as mine,
but there it works
prefectly well. I have discovered that the method doSetValue(Object value)
is called in the
ComboBoxCellEditor class. In the logic example the value parameter is an
Integer and in my
case it is a String, either "XOR" or "AND". Of course the assertion fails
when the value
parameter is a String. What am I doing wrong??
/Stefan
Re: ComboBoxPropertyDescriptor [message #81022 is a reply to message #80977] Tue, 27 May 2003 07:21 Go to previous messageGo to next message
Originally posted by: andreas.rummler.tu-ilmenau.de
Stefan Junsved schrieb:
> In the logic example the value parameter is an Integer and in my
And that's the mistake: you don't have return the String itself, but the
index of the string!
Andreas Rummler
+ Andreas Rummler +
+ Technical University of Ilmenau, Germany (__) +
+ Department Of Electronic Circuits & Systems (oo) +
+ MAIL: mailto:arummler@acm.org || | \ +
+ MAIL: mailto:andreas.rummler@tu-ilmenau.de ||----|| * +
+ WEB : http://www.inf-technik.tu-ilmenau.de/~rummler ~~ ~~ +
+ PGP : http://www.inf-technik.tu-ilmenau.de/~rummler/public.pgp +
"Programming today is a race between software engineers striving to
build bigger and better idiot-proof programs and the universe trying
to produce bigger and better idiots. So far, the universe is winning."
Richard Cook
Re: ComboBoxPropertyDescriptor [message #81078 is a reply to message #80977] Tue, 27 May 2003 08:42 Go to previous messageGo to next message
Which code were you looking at in the logic example? Try looking at the
LogicDiagram code. It has a ComboBoxPropertyDescriptor for its connection
router, which uses Integers.
Eric
Stefan Junsved wrote:
> return...;
> editpart and the
> but there it works
> is called in the
> Integer and in my
> when the value
> Thanks
> /Stefan
Re: ComboBoxPropertyDescriptor [message #81151 is a reply to message #81022] Tue, 27 May 2003 11:55 Go to previous message
The reason the default uses Integer instead of String is for translation
purposes. Once you translate into Japanese, etc., the String it no longer a
reliable way to set the current choice.
"Andreas Rummler" <andreas.rummler@tu-ilmenau.de> wrote in message
news:bavho3$n8r$1@rogue.oti.com...
> Regards,
> Andreas Rummler
> + Andreas Rummler +
> Richard Cook
Previous Topic:Deleting
Next Topic:[Draw2D] Setting Label size
Current Time: Sat Jul 26 12:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.02878 seconds
