Birt fails on report with strings [message #810795] |
Thu, 01 March 2012 10:12  |
i noticed the following.
i have POJO's mapped to birt.
when i go to preview everything is fine and dispayed correct.
when i run the report i sometimes get errors about "cannot map blabla to integer" when i check the xml it says the field is mapped as String (correct)
in the error message i noticed that the text reported as blabla always is in middle
my string might be:
Quote:somewhere /over the rainbow
so the reported error is "cannot map 'over the rainbow' to integer"
i am reporting as html in eclipse plugin (browser)
any ideas?
EDIT: i tried (just to test) to urlencode all my strings... still happens, although no slash is there...
so now i do not know what causes this strange behaviour
EDIT: i just noticed that PREVIEW in designer does work, but when i finally generate the report in viewer it fails...???
FULL ERROR example:
The following items have errors:
Data (id = 35):
+ Can not convert the value of Kals+am+Gro%C3%9Fglockner to Integer type. (Element ID:35)
CONVERT_FAILS ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not convert the value of Kals+am+Gro%C3%9Fglockner to Integer type. (Element ID:35)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1193)
at org.eclipse.birt.report.engine.internal.document.v4.DataItemExecutor.doExecute(DataItemExecutor.java:97)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.prepareChildExecutor(ContainerExecutor.java:226)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:62)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:681)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1547)
at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:238)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:105)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:322)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.core.exception.CoreException: Can not convert the value of Kals+am+Gro%C3%9Fglockner to Integer type.
at org.eclipse.birt.core.data.DataTypeUtil.toInteger(DataTypeUtil.java:276)
at org.eclipse.birt.core.data.DataTypeUtil.convert(DataTypeUtil.java:104)
at org.eclipse.birt.data.engine.impl.document.util.ExprDataReader1.getValueMap(ExprDataReader1.java:324)
at org.eclipse.birt.data.engine.impl.document.util.ExprDataReader1.getRowValue(ExprDataReader1.java:226)
at org.eclipse.birt.data.engine.impl.document.util.ExprResultSet.getValue(ExprResultSet.java:187)
at org.eclipse.birt.data.engine.impl.document.ResultIterator.getValue(ResultIterator.java:167)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.getValue(QueryResultSet.java:403)
at org.eclipse.birt.report.engine.internal.document.v4.DataItemExecutor.doExecute(DataItemExecutor.java:86)
... 76 more
+ Can not convert the value of Tue Oct 30 16:16:39 CET 2007 to Integer type. (Element ID:35)
detail : org.eclipse.birt.report.engine.api.EngineException: Can not convert the value of Tue Oct 30 16:16:39 CET 2007 to Integer type. (Element ID:35)
Caused by: org.eclipse.birt.core.exception.CoreException: Can not convert the value of Tue Oct 30 16:16:39 CET 2007 to Integer type.
at org.eclipse.birt.core.data.DataTypeUtil.toInteger(DataTypeUtil.java:239)
... 76 more
+ Retrieving binding data error. (Element ID:35)
Error.BindDataRetrivingError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Retrieving binding data error. (Element ID:35)
at org.eclipse.birt.report.engine.internal.document.v4.DataItemExecutor.doExecute(DataItemExecutor.java:102)
Caused by: java.lang.NumberFormatException
at java.math.BigDecimal.<init>(Unknown Source)
at org.eclipse.birt.core.data.DataTypeUtil.toBigDecimal(DataTypeUtil.java:357)
at org.eclipse.birt.core.data.DataTypeUtil.convert(DataTypeUtil.java:106)
... 76 more
Data (id = 33):
+ Retrieving binding data error. (Element ID:33)
detail : org.eclipse.birt.report.engine.api.EngineException: Retrieving binding data error. (Element ID:33)
... 76 more
Data (id = 37):
+ Retrieving binding data error. (Element ID:37)
probably i should also note that although i have plenty of properties on my object
i only report THREE but on the report it tries to put ALL of em!!!
[Updated on: Thu, 01 March 2012 10:50] by Moderator
Re: Birt fails on report with strings [message #814199 is a reply to message #813965] |
Tue, 06 March 2012 01:40   |
how do i set log details?
i start the viewer like this:
public void loadReport(String reportName) {
System.out.println("loading report '"+reportName+"'");
HashMap<String, Object> myparms = new HashMap<String, Object>();
HashMap<String, String> emitmap = new HashMap<String, String>();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
//myparms.put("RESOURCE_FOLDER_KEY", "c:/myresources");
myparms.put("ALLOW_PAGE", "false");
myparms.put("SHOW_PARAMETER_PAGE", "false");
//Report Parameters
emitmap.put("Top Count", "6");
emitmap.put("Top Percentage", "15");
myparms.put("EMITTER_OPTIONS_KEY", emitmap);
//myparms.put("MAX_ROWS_KEY", "500");
WebViewer.display(reportName, browser, myparms);
update: i tried to add
myparms.put("BIRT_VIEWER_LOG_LEVEL", "FINE");
myparms.put("BIRT_VIEWER_LOG_DIR", "c:/temp/java/birt/");
but i am not sure if this is correct.
although i do get plenty of logs it does not give me an error nor warning in the VIEWER
(i have no clue why appying other settings to the viewer does affect the preview in the designer?!)
when i change from HTML to PDF and use preview in the DESIGNER i get this:
Quote:!ENTRY org.eclipse.core.filebuffers 4 2 2012-03-06 08:29:24.216
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.ui.texteditor.spelling.SpellingReconcileStrategy.<init>(SpellingReconcileStrategy.java:156)
at org.eclipse.ui.editors.text.TextSourceViewerConfiguration.getReconciler(TextSourceViewerConfiguration.java:389)
at org.eclipse.wst.sse.ui.StructuredTextEditor.handleElementContentReplaced(StructuredTextEditor.java:2442)
at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:468)
at org.eclipse.ui.texteditor.AbstractTextEditor$ElementStateListener.execute(AbstractTextEditor.java:599)
at org.eclipse.ui.texteditor.AbstractTextEditor$ElementStateListener.elementContentReplaced(AbstractTextEditor.java:471)
at org.eclipse.ui.editors.text.TextFileDocumentProvider$FileBufferListener.bufferContentReplaced(TextFileDocumentProvider.java:265)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager$5.run(TextFileBufferManager.java:730)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.fireBufferContentReplaced(TextFileBufferManager.java:728)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer.handleFileContentChanged(ResourceTextFileBuffer.java:517)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer$2.execute(ResourceFileBuffer.java:151)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer$SafeFileChange.run(ResourceFileBuffer.java:86)
at org.eclipse.ui.internal.editors.text.UISynchronizationContext.run(UISynchronizationContext.java:34)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.execute(TextFileBufferManager.java:629)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer$FileSynchronizer.resourceChanged(ResourceFileBuffer.java:180)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:395)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1530)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2353)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:71)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:63)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.IDEFileReportProvider.saveFile(IDEFileReportProvider.java:377)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.IDEFileReportProvider.saveReport(IDEFileReportProvider.java:145)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.IDEFileReportProvider.saveReport(IDEFileReportProvider.java:122)
at org.eclipse.birt.report.designer.ui.preview.editors.ReportPreviewEditor.doSave(ReportPreviewEditor.java:111)
at org.eclipse.birt.report.designer.ui.preview.editors.ReportPreviewFormPage.onBroughtToTop(ReportPreviewFormPage.java:98)
at org.eclipse.birt.report.designer.ui.editors.MultiPageReportEditor.prePageChanges(MultiPageReportEditor.java:906)
at org.eclipse.birt.report.designer.ui.editors.IDEMultiPageReportEditor.prePageChanges(IDEMultiPageReportEditor.java:525)
at org.eclipse.birt.report.designer.ui.editors.MultiPageReportEditor.pageChange(MultiPageReportEditor.java:830)
at org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(MultiPageEditorPart.java:290)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2745)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1432)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at lumo.application.Application.start(Application.java:21)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
[Updated on: Tue, 06 March 2012 02:33] by Moderator
Re: Birt fails on report with strings [message #814715 is a reply to message #814199] |
Tue, 06 March 2012 14:57   |
Ludwig,
When you run it and get the error can you check the workspace folder:
\.metadata\.plugins\org.eclipse.birt.report.viewer\logs
to see if any errors show up in the log file?
Jason
> //Report Parameters
FUDForum. Page generated in 0.55815 seconds
