Home » Eclipse Projects » Equinox » Restricting package access with PackagePermission
Restricting package access with PackagePermission [message #810119] Wed, 29 February 2012 13:11 Go to next message
My question is simple. For a given plugin, is it possible to limit its access to only a restricted set of packages? And deny access to other packages?
My context is the following. I have a server application based on equinox, that can accept new third party plugins via upload from users. The code that is uploaded to the server is not trusted and could be malicious. I want these plugins to have access only to a limited set of packages.
E.g.: the code requires bundle "org.eclipse.core.runtime". This bundle exports 3 packages:
* org.eclipse.core.internal.preferences.legacy
* org.eclipse.core.internal.runtime
* org.eclipse.core.runtime
I want the code to be able to access only classes from the *.runtime package.
I have tried using PackagePermission. But this seems to work only if the bundle explicitly declares that it uses those packages. I.e. PackagePermission seems to be effective only during plugin load, by analizing the manifest of the loaded plugin. PackagePermission doesn't seem to be evaluated at runtime, e.g. by the class loader, when the plugin actually tries to access classes from the restricted packages.
Thank you in advance.
Cristian.
Re: Restricting package access with PackagePermission [message #810154 is a reply to message #810119] Wed, 29 February 2012 14:13 Go to previous messageGo to next message
When you use PackagePermission how are you using it? I assume you are configuring it using the ConditionalPermissionAdmin (or PermisionAdmin) services? Also, I have to confirm you are launching eclipse with security enabled. Permissions are only checked if you have security enabled (i.e. setting the eclipse.security=osgi configuration property).
Tom
Re: Restricting package access with PackagePermission [message #810227 is a reply to message #810154] Wed, 29 February 2012 16:43 Go to previous messageGo to next message
Hello Tom,
Thank you for your reply.
I start equinox with a security manager that points to a policy that grants AllPermission:
-Djava.security.manager -Djava.security.policy=${workspace_loc}\test.permisiuni_osgi.main\all.policy
First: I install the plugin:
pluginB = Activator.getDefault().getBundle().getBundleContext().installBundle(bLocationString);
Second: I add a new permission using ConditionalPermissionAdmin:
// add deny permissions
ConditionalPermissionInfo info = permissionAdmin.newConditionalPermissionInfo(
	bundle.getLocation() + "_2",
	new ConditionInfo[]{
		new ConditionInfo(BundleLocationCondition.class.getName(), new String[] {bundle.getLocation()})
	, new PermissionInfo[]{
			new PermissionInfo(PackagePermission.class.getName(), "p2", "import")
	ConditionalPermissionInfo.DENY
Using the above construct, I wish to restrict the access to the "p2" package.
Third: I start the plugin.
pluginB.start();
Results:
If the plugin declares in the manifest file that it imports package "p2", then the start methods throws an exception, and the plugin won't start. However, if the plugin doesn't declare the "p2" import, but its code tries to access the class (e.g. Class.forName("p2.MyClass"), I get no security exception. And I would expect/want to have one (security exception).
Cristian.
Re: Restricting package access with PackagePermission [message #810236 is a reply to message #810227] Wed, 29 February 2012 16:59 Go to previous messageGo to next message
I am guessing you are using Require-Bundle also? Require-Bundle will get you access to all packages exported by a bundle. So if the bundle in question is using Require-Bundle then the PackagePermission does not help. You can use the org.osgi.framework.BundlePermission for that. But it is much more fine grain since you have to allow/deny requiring the "complete" bundle. That is the disadvantage of require-bundle, you have no control over the packages you get access to.
Re: Restricting package access with PackagePermission [message #810239 is a reply to message #810236] Wed, 29 February 2012 17:00 Go to previous messageGo to next message
Thomas Watson wrote on Wed, 29 February 2012 15:59
... But it is much more fine grain ...
I meant to say "But it is much more coarse grain ..."
Re: Restricting package access with PackagePermission [message #810454 is a reply to message #810239] Thu, 01 March 2012 00:36 Go to previous messageGo to next message
Yes indeed, I use the Require Bundle.
So if I understand correctly, my only option is to deny the use of "Require bundle" and to force the third party plugins use the "import package" statements. This way, if the plugin uses "illegal" packages, it is stopped from the beginning (i.e. during the plugin startup). So there is no way to make equinox control the package access during runtime (i.e. during class instantiation).
Is this understanding correct?
If yes, another thought crosses my mind: using a custom classloader for the plugin, that checks for permissions during "findClass()" calls.
Thank you.
Cristian.
Re: Restricting package access with PackagePermission [message #810743 is a reply to message #810454] Thu, 01 March 2012 08:54 Go to previous messageGo to next message
Cristian Mising name wrote on Wed, 29 February 2012 23:36
Thank you.
Cristian.
If you don't mind using Equinox specific APIs then you could hook into the class loader of the bundles. Equinox Framework Hooks
I would suggest using the org.eclipse.osgi.framework.adaptor.ClassLoaderDelegateHook hook and the preFind* methods. This would allow you to throw a runtime exception (like SecurityException) or a ClassNotFoundException if you detect a particular bundle is trying to load a class you don't want them to.
HTH.
Re: Restricting package access with PackagePermission [message #810747 is a reply to message #810743] Thu, 01 March 2012 09:02 Go to previous messageGo to next message
Thanks for the tip.
I understand that my first statement is also correct, right? I.e., besides modifying the class loader (or using a hook), I can block the access to a class only by doing this:
Cristian.
Re: Restricting package access with PackagePermission [message #810784 is a reply to message #810747] Thu, 01 March 2012 09:55 Go to previous messageGo to next message
Cristian Mising name wrote on Thu, 01 March 2012 08:02
Thanks for the tip.
Cristian.
Sorry, I split your comment to insert my reply and forgot to Wink
Yes, your understanding is correct. Require-Bundle is a coarse grained dependency and therefore only has a coarse grain permission that allows you to either allow the whole bundle to be required or deny the whole thing.
Tom.
Re: Restricting package access with PackagePermission [message #810825 is a reply to message #810784] Thu, 01 March 2012 10:45 Go to previous message
Thanks a lot for your feedback.
Cristian.
Previous Topic:How to accept certificates p2.director
Next Topic:ERROR
Current Time: Sat Jul 26 11:29:11 EDT 2025
Powered by FUDForum. Page generated in 0.04754 seconds
