Home » Modeling » TMF (Xtext) » Annotation with Enum values(Problems generating annotations with enum values)
Annotation with Enum values [message #809803] |
Wed, 29 February 2012 04:27  |
I'm trying to create some JPA classes from my model.
When creating the annotations for Temporal types I run into a problem to create the correct annotation values @Temporal(TemporalType.DATE).
I can see the various EnumerationValues I can create but none of these seem to work for me. The closest seems to be:
TypesFactory::eINSTANCE.createJvmEnumAnnotationValue
but I have no idea how to create the correct literal.
The below code fails to generate the class without any exception being thrown (commenting anno.values+=v out generates the code but obviously doesn't add the value ...)
Any clues as to what I do wrong how to overcome this issue are very appreciated
Ingo
val anno = property.toAnnotation("javax.persistence.Temporal")
val v = TypesFactory::eINSTANCE.createJvmEnumAnnotationValue
val op = anno.annotation.members.filter(typeof(JvmOperation)).filter(o|o.simpleName == "value").head
v.operation = op
val lit = typesFactory.createJvmEnumerationLiteral
lit.setSimpleName("Date")
lit.setType(property.newTypeRef(typeof(TemporalType)))
v.values+=lit
anno.values+=v
annotations+=anno
body=['''return this.dateCreated;''']
Re: Annotation with Enum values [message #809963 is a reply to message #809883] |
Wed, 29 February 2012 09:02   |
... and for whoever might need this ...
I abstracted the above code into a separate util class:
@Inject TypeReferences typeReferences
def addJvmEnumValueToAnnotation(EObject sourceElement, JvmAnnotationReference annotationReference,
String valueName, Class<?> enumerationClass, String literalName){
val op = annotationReference.annotation.getDeclaredOperations().filter(o|o.simpleName == valueName).head
v.operation = op
val enumType = typeReferences.getTypeForName(enumerationClass, sourceElement).type as JvmEnumerationTypeImplCustom
val literal = enumType.literals.filter(o|o.simpleName == literalName).head
v.values+=literal
annotationReference.values+=v
reducing the necessary code to add an enumeration value to:
val anno = property.toAnnotation(typeof(javax.persistence.Temporal))
property.addJvmEnumValueToAnnotation(anno,"value",typeof(javax.persistence.TemporalType),"TIMESTAMP")
[Updated on: Wed, 29 February 2012 09:04] by Moderator
JvmModelInferrer ConvenienceMethods for Annotations (Re: Annotation with Enum values) [message #1010587 is a reply to message #809803] |
Sun, 17 February 2013 14:40   |
Thanks for the clue .. sorting out that stuff took me far too long.
Feel free to use that
Usage:
//Annotation with StrinParam
annotations += record.toAnnotation(typeof(javax.persistence.Table),
newParamList.addStringParam("name", record.TableName) );
//Annotation with AnnotationParam
for (q : entity.methods.filter( typeof(RecordQueryDeclaration)) )
queryAnnotations += entity.toAnnotation(
typeof(javax.persistence.NamedQuery),
newParamList
.addStringParam("name", q.Identifier)
.addStringParam("query", q.QueryString) );
annotations += entity.toAnnotation(
typeof(javax.persistence.NamedQueries),
newParamList.addAnnotationParam("value", queryAnnotations) );
//Annotation with EnumParam
annotations += field.toAnnotation(
typeof(javax.persistence.Enumerated),
newParamList.addEnumParam(field, "value", EnumType::STRING)
Lib :
import com.google.common.base.Function
import com.google.inject.internal.Nullable
import java.util.ArrayList
import java.util.Collection
import java.util.List
import java.util.Map
import java.util.TreeMap
import org.eclipse.emf.common.notify.Notifier
import org.eclipse.emf.ecore.EObject
import org.eclipse.xtext.common.types.JvmAnnotationAnnotationValue
import org.eclipse.xtext.common.types.JvmAnnotationReference
import org.eclipse.xtext.common.types.JvmAnnotationType
import org.eclipse.xtext.common.types.JvmAnnotationValue
import org.eclipse.xtext.common.types.JvmBooleanAnnotationValue
import org.eclipse.xtext.common.types.JvmEnumAnnotationValue
import org.eclipse.xtext.common.types.JvmOperation
import org.eclipse.xtext.common.types.JvmStringAnnotationValue
import org.eclipse.xtext.common.types.JvmTypeAnnotationValue
import org.eclipse.xtext.common.types.JvmTypeReference
import org.eclipse.xtext.common.types.TypesFactory
import org.eclipse.xtext.common.types.impl.JvmEnumerationTypeImplCustom
import javax.inject.Inject
import org.eclipse.xtext.common.types.util.TypeReferences
import org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder
class CodeGenAnnotationHelpers {
@Inject extension TypeReferences
@Inject extension JvmTypesBuilder typesBuilder
def JvmAnnotationReference toAnnotation(@Nullable EObject sourceElement, Class<?> annotationType, Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> namedParams) {
val a = sourceElement.toAnnotation(annotationType) => [
for(namedValue : namedParams.entrySet) {
val annotationValueFactories = namedValue.value;
values += annotationValueFactories.map([f|f.apply(annotation)]);
} //for named param
return a;
def Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> newParamList() {
return new TreeMap<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>>();
def Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> addStringParam(Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map,
String paramName, String... stringValues) {
return addValuesG(map,
TypesFactory::eINSTANCE.createJvmStringAnnotationValue,
paramName, stringValues,
[ p| return (p as JvmStringAnnotationValue).values; ]
def Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> addTypeParam(Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map,
String paramName, JvmTypeReference... typeValues) {
TypesFactory::eINSTANCE.createJvmTypeAnnotationValue,
paramName, typeValues,
[ p| return (p as JvmTypeAnnotationValue).values; ]
def Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> addAnnotationParam(Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map,
String paramName, Collection<JvmAnnotationReference> annotationValues) {
TypesFactory::eINSTANCE.createJvmAnnotationAnnotationValue,
paramName, annotationValues,
[ p| return (p as JvmAnnotationAnnotationValue).annotations; ]
String paramName, JvmAnnotationReference... annotationValues) {
val List<JvmAnnotationReference> valuesAsList = annotationValues;
return addAnnotationParam(map, paramName, valuesAsList);
def Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> addBooleanParam(Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map,
String paramName, Boolean... booleanValues) {
TypesFactory::eINSTANCE.createJvmBooleanAnnotationValue,
paramName, booleanValues,
[ p| return (p as JvmBooleanAnnotationValue).values; ]
def <T extends Enum<?>> Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>>
addEnumParam(Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map,
Notifier context,
String paramName, T... enumValues) {
val trEnumValue = enumValues.head.getClass().canonicalName.getTypeForName(context);
val enumType = trEnumValue.type as JvmEnumerationTypeImplCustom
val packagedValues = enumValues.map([v|
val packagedValue = TypesFactory::eINSTANCE.createJvmEnumerationLiteral;
packagedValue.setType(trEnumValue);
return enumType.literals.filter([l| v.name.equals( l.simpleName )]).head;
TypesFactory::eINSTANCE.createJvmEnumAnnotationValue,
paramName, packagedValues,
[ p| return (p as JvmEnumAnnotationValue).values;]
def <ValueType, AnotationValueType extends JvmAnnotationValue>
addValuesG( Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map,
JvmAnnotationValue newAnotationParameterAssignment,
String paramName, ValueType[] valuesOfNamedAnnotationParameter,
Function<JvmAnnotationValue, ? extends List<ValueType>> valuesExtr
val effMap = if (map != null) map else newParamList();
if (valuesOfNamedAnnotationParameter.contains(null))
throw new IllegalArgumentException("Value for Annotation-Param " + paramName + " must not be null.");
effMap.addValue2AnnotationParamMap(paramName, [aType |
val op = aType.members.filter(typeof(JvmOperation)).filter(o|paramName.equals(o.simpleName)).head;
newAnotationParameterAssignment.operation = op;
valuesExtr.apply(newAnotationParameterAssignment) += valuesOfNamedAnnotationParameter;
return newAnotationParameterAssignment;
return effMap;
def Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> addValue2AnnotationParamMap(Map<String, List<Function<JvmAnnotationType, JvmAnnotationValue>>> map, String paramName, Function<JvmAnnotationType, JvmAnnotationValue> valueFactory) {
val effParamName =
if (paramName != null) {
if (!"".equals(paramName)) paramName else "value";
} else "value";
var List<Function<JvmAnnotationType, JvmAnnotationValue>> valueList = map.get(effParamName)
if (valueList == null) {
valueList = new ArrayList<Function<JvmAnnotationType, JvmAnnotationValue>>();
map.put(effParamName, valueList);
} else throw new IllegalArgumentException("Duplicate creation of the '" + effParamName + "' parameter.");
valueList.add(valueFactory);
return map;
} //class
Current Time: Sat Jul 26 11:05:01 EDT 2025
Powered by FUDForum. Page generated in 0.04675 seconds
