Home » Archived » BIRT » Bookmarks missing from PDF reports
Bookmarks missing from PDF reports [message #809117] Tue, 28 February 2012 08:53 Go to next message
We previously used the BIRT viewer to generate pdf reports and these showed with bookmarks down the left hand side.
We have now moved to use the apis to integrate the running of the reports in our application but the bookmarks are no longer generated.
How do I enable the generation of PDF bookmarks?
Re: Bookmarks missing from PDF reports [message #809593 is a reply to message #809117] Tue, 28 February 2012 21:52 Go to previous messageGo to next message
You should not have to do anything to support this other than have the
toc entry in the report. I use the following code with the attached
report and it shows my bookmarks in pdf:
import java.util.Locale;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.impl.RunAndRenderTask;
import org.eclipse.birt.report.engine.api.script.IReportContext;
public class RunAndRenderTaskTest {
public void runReport() throws EngineException
RunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
//config.setLogConfig("c:/dwn", Level.SEVERE);
//config.setResourcePath("C:/work/workspaces/3.7.1workspaces/BIRT
Metal/APIs/resources");
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/bookmark.rptdesign");
task = (RunAndRenderTask) engine.createRunAndRenderTask(design);
task.setLocale(new Locale("en", "US"));
//IReportContext irc = task.getReportContext();
//task.setParameterValue("Top Count", (new Integer(5)));
//task.validateParameters();
//HTMLRenderOption options = new HTMLRenderOption();
//options.setImageDirectory("./");
//options.setOutputFileName("output/resample/external.html");
//options.setOutputFormat("html");
//options.setEmbeddable(false);
//options.setEnableMetadata(true);
//options.setEnableInlineStyle(false);
//options.setEnableAgentStyleEngine(true);
//options.setEnableCompactMode(true);
PDFRenderOption options = new PDFRenderOption();
options.setOutputFileName("output/resample/bookmark.pdf");
options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
options.setOutputFormat("pdf");
//EXCELRenderOption options = new EXCELRenderOption();
//options.setOutputFormat("xls");
//options.setOutputFileName("output/resample/customers.xls");
//options.setWrappingText(true);
//options.setImageHandler(new HTMLServerImageHandler());
//options.setSupportedImageFormats("JPG;PNG;BMP;SVG;GIF");
//options.setOutputFileName("output/resample/testlibrary.html");
//options.setOutputFormat("ppt");
//options.setOutputFileName("output/resample/hidefooter2.odp");
//options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
//options.setOutputFormat("odp");
task.setRenderOption(options);
task.run();
//irc = task.getReportContext();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTaskTest ex = new RunAndRenderTaskTest( );
ex.runReport();
System.exit(0);
catch ( Exception e )
e.printStackTrace();
Re: Bookmarks missing from PDF reports [message #809596 is a reply to message #809117] Tue, 28 February 2012 21:52 Go to previous messageGo to next message
try{
task.run();
task.close();
engine.destroy();
* @param args
try
ex.runReport();
System.exit(0);
Re: Bookmarks missing from PDF reports [message #809599 is a reply to message #809117] Tue, 28 February 2012 21:52 Go to previous messageGo to next message
try{
task.run();
task.close();
engine.destroy();
* @param args
try
ex.runReport();
System.exit(0);
Re: Bookmarks missing from PDF reports [message #809602 is a reply to message #809117] Tue, 28 February 2012 21:52 Go to previous messageGo to next message
try{
task.run();
task.close();
engine.destroy();
* @param args
try
ex.runReport();
System.exit(0);
Re: Bookmarks missing from PDF reports [message #809605 is a reply to message #809117] Tue, 28 February 2012 21:52 Go to previous messageGo to next message
try{
task.run();
task.close();
engine.destroy();
* @param args
try
ex.runReport();
System.exit(0);
Re: Bookmarks missing from PDF reports [message #810588 is a reply to message #809605] Thu, 01 March 2012 04:41 Go to previous messageGo to next message
Thanks for that. The code we are using is almost exactly the same, and using your code I still don't get any bookmarks with our reports.
Unhelpfully I can't download your report to see if we are missing anything there because of a security policy set at this end. Is there any difference in the way TOC entries are produced between BIRT versions 2.5 and 3.7? Most of our reports were produced under the earlier version but we are in the process of moving to 3.7 as well as using the API.
Any reports I open whether produced under version 2.5 or resaved as 3.7 show with bookmarks when I run them through eclipse, just not when run through our application.
Re: Bookmarks missing from PDF reports [message #810860 is a reply to message #810588] Thu, 01 March 2012 11:10 Go to previous messageGo to next message
What BIRT version are you having the issue in? I can post the report
xml in the message if that will help. You should be able to cut and
paste it.
Jason
Re: Bookmarks missing from PDF reports [message #810861 is a reply to message #810860] Thu, 01 March 2012 11:16 Go to previous messageGo to next message
That would be useful, thanks. We are having problems in BIRT 3.7.
Re: Bookmarks missing from PDF reports [message #810871 is a reply to message #810861] Thu, 01 March 2012 11:20 Go to previous message
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet"
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
<text-property
name="heading">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
<text-property
name="heading">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
<text-property
name="heading">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
<text-property
name="heading">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails
where ordernumber < 10104]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression>
</structure>
</list-property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="43">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["ORDERNUMBER"]</expression>
<structure name="toc">
<expression name="expressionValue"
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="44">
<cell id="45">
<data id="56">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
<cell id="49"/>
</row>
</header>
<footer>
<row id="50">
<cell id="51"/>
<cell id="52"/>
<cell id="53"/>
<cell id="54"/>
<cell id="55"/>
</row>
</footer>
</group>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property name="whiteSpace">nowrap</property>
<property
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</report>
Previous Topic:Output encoding
Next Topic:how to easily resolve errrors
Current Time: Wed Jul 23 21:44:04 EDT 2025
Powered by FUDForum. Page generated in 0.07381 seconds
