Home » Language IDEs » C / C++ IDE (CDT) » Can't start Indigo
Can't start Indigo [message #809228] Tue, 28 February 2012 11:12 Go to next message
Since I installed Juno, I cannot launch Indigo anymore. (I'm on Linux).
Are there some files to delete ?
The -debug options doesn't give any info.
The -consoleLog option shows many errors (NullPointerException...)
See the following message.
Thanks.
[Updated on: Tue, 28 February 2012 11:32] by Moderator
Re: Can't start Indigo [message #809247 is a reply to message #809228] Tue, 28 February 2012 11:32 Go to previous messageGo to next message
!SESSION 2012-02-28 17:27:53.124 -----------------------------------------------
eclipse.buildId=M20110909-1335
java.version=1.6.0_22
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product -consoleLog
!ENTRY org.eclipse.osgi 4 0 2012-02-28 17:28:04.895
!MESSAGE An error occurred while automatically activating bundle org.eclipse.mylyn.tasks.ui (246).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin for bundle org.eclipse.mylyn.tasks.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:171)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.util.Util.safeLoadExecutableExtension(Util.java:879)
at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.createContributionItem(DynamicToolBarContributionItem.java:183)
at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.getContributionItem(DynamicToolBarContributionItem.java:176)
at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.createControl(DynamicToolBarContributionItem.java:278)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:97)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88)
at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265)
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3867)
at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3878)
at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1150)
at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1036)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1211)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/mylyn/commons/identity/spi/IdentityConnector
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2406)
at java.lang.Class.getConstructor0(Class.java:2716)
at java.lang.Class.newInstance0(Class.java:343)
at java.lang.Class.newInstance(Class.java:325)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:166)
... 70 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.mylyn.commons.identity.spi.IdentityConnector
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
... 76 more
Root exception:
... 76 more
!ENTRY org.eclipse.ui 4 4 2012-02-28 17:28:04.957
!MESSAGE Class load Failure: 'org.eclipse.mylyn.internal.tasks.ui.TaskTrimWidget'
!ENTRY org.eclipse.ui 4 0 2012-02-28 17:28:04.963
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.mylyn.tasks.ui was unable to load class org.eclipse.mylyn.internal.tasks.ui.TaskTrimWidget.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.mylyn.tasks.ui (246).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 52 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin for bundle org.eclipse.mylyn.tasks.ui is invalid
... 64 more
... 70 more
... 76 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-02-28 17:28:04.980
!MESSAGE Plug-in org.eclipse.mylyn.tasks.ui was unable to load class org.eclipse.mylyn.internal.tasks.ui.TaskTrimWidget.
!STACK 0
... 64 more
... 70 more
... 76 more
!ENTRY org.eclipse.ui 4 0 2012-02-28 17:28:04.999
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.jface.action.ControlContribution.computeWidth(ControlContribution.java:54)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:100)
Re: Juno / Indigo [message #809250 is a reply to message #809228] Tue, 28 February 2012 11:34 Go to previous messageGo to next message
What is your operating system?
On Windows, your installation of Juno and Indigo are made in a different folder, so, you can't make a mistake
On Linux, you can type 'which eclipse' to show you what Eclipse you are using.
I think, you just have to specify the real path on your executable to launch Juno or Indigo.
EDIT: What do you mean about "I cannot launch Indigo anymore"?
[Updated on: Tue, 28 February 2012 11:37] by Moderator
Re: Juno / Indigo [message #809252 is a reply to message #809250] Tue, 28 February 2012 11:37 Go to previous messageGo to next message
Linux.
I launch both in the same way. Juno does work, but Indigo doesn't.
I guess some common files in my profile directory has been updated by Juno, so Indigo doesn't work anymore. ut I'd like to come back to Indigo.
Re: Juno / Indigo [message #809256 is a reply to message #809252] Tue, 28 February 2012 11:41 Go to previous messageGo to next message
Weird...
Hum, on Linux, your installation of Eclipse are made in separated folders, no? (I am using Windows for Eclipse)
In order to come back to Indigo, you can try reinstall it or remove Juno and reinstall Indigo?
Re: Juno / Indigo [message #809261 is a reply to message #809256] Tue, 28 February 2012 11:49 Go to previous messageGo to next message
They are in separate folders.
I'd like to avoid to uninstall and reinstall, because I have some plug-ins.
The problem seems to come from Mylin.
[Updated on: Tue, 28 February 2012 11:56] by Moderator
Re: Juno / Indigo [message #809289 is a reply to message #809261] Tue, 28 February 2012 12:37 Go to previous messageGo to next message
I resolved the problem by deleting in the plugins directory all the jar files related to Mylyn, and by checking all the updates afterwards.
Re: Can't start Indigo [message #904187 is a reply to message #809228] Mon, 27 August 2012 20:49 Go to previous message
I had a very similar problem with starting Juno, and it was due to a superuser permissions thing.
Eclipse was installed in my /usr/share directory, and ran fine if I used sudo:
sudo /usr/share/eclipse
However, that's dangerous, so the permanent fix for me was moving the eclipse directory to my home directory and running it from there:
sudo mv /usr/share/eclipse ~
~/eclipse/eclipse
Cheers.
Previous Topic:Setting dynamically build environment
Next Topic:Can't generate AST correctly when parsing a C source code(written on Windows) under Linux
Current Time: Wed Jul 30 17:21:42 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
