Home » Archived » XML Schema Definition (XSD) » Problem with xsd and xml validation using JAXB(InvalidRegex:Pattern value '([a-zA-Z0-9\_\.\*\%\-]){1,28}' is not a valid regular expression. The reported error was: 'This expression is not supported in the current option setting.')
Problem with xsd and xml validation using JAXB [message #809163] Tue, 28 February 2012 09:53 Go to next message
I am validating the xml file with xsd. I am getting a problem when there is a regular expression which contains the escape characters
For example
my xsd is like :
<xs:simpleType name="DestinationStringLimitedType">
<xs:restriction base="xs:string">
<xs:pattern value="([a-zA-Z0-9\_\.\*\%\-]){1,28}"/>
<xs:whiteSpace value="collapse"/>
</xs:restriction>
</xs:simpleType>
when i am trying to validate using jaxb i'm getting the error as
And when i remove the escape characters it is not giving any errors that is if the xsd is <xs:pattern value="([a-zA-Z0-9_.*%-]){1,28}"/> .
1) How to make JAXB work with this regular expression(with escape characters)?
2) How to configure Xerces to make it parse this regular expression?
Can any one help me with the above problem ?
Re: Problem with xsd and xml validation using JAXB [message #809223 is a reply to message #809163] Tue, 28 February 2012 11:04 Go to previous message
Manoj,
This newsgroup is for asking questions about Eclipse's XSD model APIs,
not a general XML Schema newsgroup. More comments below.
On 28/02/2012 3:53 PM, Manoj Kumar wrote:
> For example
> my xsd is like :
I don't believe you need to escape characters in a character group.
> </xs:restriction>
> </xs:simpleType>
> characters)?
I don't think you need then and I don't think they're allowed.
If the expression is valid, Xerces will like it, otherwise you'll get an
error. There's no avoiding that.
Previous Topic:xpath error
Next Topic:Include several XSD files
Current Time: Thu Jul 24 23:03:28 EDT 2025
Powered by FUDForum. Page generated in 0.09350 seconds
