Home » Language IDEs » PHP Development Tools (PDT) » Code completion...
Code completion... [message #80878] Fri, 26 September 2008 23:44 Go to next message
I don't know if this was brought up before, or what its referred to, but I
work with cakePHP a lot, and I run into a problem that I don't get code
completion on custom Models when I reference them from the controller.
For example I will have my userModel.php
class MyModel extends AppModel {
var $name;
and in my userController.php I will have
class UserController extends AppController {
echo $this->MyModel->save($this->form(data);
$this->MyModel->[code completion jumps in]
does anyone have a glue how to make this work?
Re: Code completion... [message #80883 is a reply to message #80878] Sun, 28 September 2008 20:08 Go to previous messageGo to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
The only way PDT can tell what type $this->MyModel is, is if you write a
PHPDoc comment.
Given that it's cakephp and the mymodel object is created via some
hidden runtime voodoo, there's no way for PDT to tell what type it is.
You can try adding a doc comment identifying it to your controller,
hopefully cake will play nice with that.
> I work with cakePHP a lot, and I run into a problem that I don't get
> code completion on custom Models when I reference them from the controller.
> var $name;
Re: Code completion... [message #83387 is a reply to message #80883] Tue, 11 November 2008 07:05 Go to previous messageGo to next message
Originally posted by: michael.zend.com
Not exactly. If you have an assignment to this variable in your class
constructor it will be taken into account also.
For example:
class B {
function foo() {
class A {
var $v;
function __construct() {
$this->v = new B();
$a = new A();
$a->v->foo(); // here foo() is proposed by Code Assist
"Tom Walter" <eclipsenews.20.epm@spamgourmet.com> wrote in message
news:48E01C8B.3060807@spamgourmet.com...
> PHPDoc comment.
> Given that it's cakephp and the mymodel object is created via some hidden
>> I work with cakePHP a lot, and I run into a problem that I don't get code
>> var $name;
Re: Code completion... [message #83658 is a reply to message #83387] Thu, 13 November 2008 08:13 Go to previous messageGo to next message
Hello there,
> For example:
> class B {
> function foo() {
> class A {
> var $v;
> $this->v = new B();
> $a = new A();
This is fine as long as you are not using Singletons. Consider this :
class B {
private $instance ;
public static function GetInstance() {
if(empty(self::$instance)) {
self::$instance = new B ; }
return self::$instance ;
function foo() {
class A {
var $v;
$this->v = B::GetInstance();
$a = new A();
$a->v->foo(); // No Code Assist here
In that case, adding a PHPDoc block for "var $v" is the only way (AFAIK)
to get Code Assist to work.
Adding a PHPDoc block to the GetInstance static method in order to specify
the return type also helps but only inside the class context.
Re: Code completion... [message #83672 is a reply to message #83658] Thu, 13 November 2008 09:06 Go to previous messageGo to next message
Such examples can become a use cases for our Type Inference engine that can
be improved.
Thanks!
"Romain Riviere" <romain.riviere@gmail.com> wrote in message
news:2c5ced46408675a79299ca9818d638e2$1@www.eclipse.org...
> Hello there,
>> For example:
>> class B {
>> function foo() {
>> class A {
>> var $v;
>> $this->v = new B();
>> $a = new A();
> class B {
> private $instance ;
> function foo() {
> class A {
> var $v;
> $a = new A();
Re: Code completion... [message #83688 is a reply to message #83672] Thu, 13 November 2008 09:32 Go to previous message
> be improved.
> Thanks!
Anytime :) That's the least I could do !
Previous Topic:Validate Goes Bad w/No Changes
Next Topic:java.lang.IllegalArgumentException
Current Time: Thu Sep 18 17:35:35 EDT 2025
Powered by FUDForum. Page generated in 0.05069 seconds
