Home » Archived » M2M (model-to-model transformation) » [ATL] [Solved] Calling a rule a fixed number of times
icon5.gif  [ATL] [Solved] Calling a rule a fixed number of times [message #808374] Mon, 27 February 2012 13:12 Go to next message
How to call an ATL rule a fixed number of times?
For instance 30 or 108.
[Updated on: Tue, 28 February 2012 08:39] by Moderator
Re: Calling a rule a fixed number of times [message #808397 is a reply to message #808374] Mon, 27 February 2012 13:42 Go to previous messageGo to next message
Perhaps the OCL index loop idiom will help
Sequence{1..38}->forAll(i : Integer| ...)
Ed Willink
On 27/02/2012 18:12, Missing name Mising name wrote:
> How to call a rule a fixed number of times?
> Regards
Re: Calling a rule a fixed number of times [message #808419 is a reply to message #808397] Mon, 27 February 2012 14:16 Go to previous messageGo to next message
Dear Edward,
Thank you for your answer.
How do you use that structure in a reference, so all the generated targets are assigned to the same source element ?
For instance, would this work? (I thought forAll returned a boolean value) :
t.contains38 <- Sequence{1..38}->forAll(i : Integer | thisModule.createOne())
What I want to have is t referencing the 38 elements.
Thank you very much again.
Best regards
Re: Calling a rule a fixed number of times [message #808801 is a reply to message #808419] Tue, 28 February 2012 01:42 Go to previous messageGo to next message
Dear Edward Willink,
I have tried your approach as follows:
t.contains3 <- (c -> forAll(i| thisModule.createOne())),
where c is defined as follows:
c : Sequence(Integer) = Sequence{1, 2, 3}
I have the following problem:
org.eclipse.m2m.atl.engine.emfvm.VMException: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to java.lang.Boolean
I didn't manage to create a Sequence using the OCL index loop idiom that you mentioned as:
Sequence{1..38}
The '..' are not recognised, but I can create a Sequence of n elements recursively as well.
Do you know (or any one reading this thread Smile ) how to solve the problem related to the Boolean casting to create N number of target elements?
Thank you very much.
Re: Calling a rule a fixed number of times [message #808807 is a reply to message #808801] Tue, 28 February 2012 01:50 Go to previous messageGo to next message
I'm afraid that I cannot help you with ATL which I have never succeeded
in understanding. ATL uses its own OCL-like sub-language which appears
to fail to implement .. properly.
Ed Willink
> java.lang.Boolean
> Sequence{1..38}
> Do you know (or any one reading this thread :) ) how to solve the
> elements?
> Best regards,
Re: Calling a rule a fixed number of times [message #808813 is a reply to message #808807] Tue, 28 February 2012 01:59 Go to previous messageGo to next message
Thank you anyway Edward.
Does anyone know the answer?
How to create a fixed number of targets? (or how to call a rule a fixed number of times?)
Thank you very much,
Re: Calling a rule a fixed number of times [message #808855 is a reply to message #808813] Tue, 28 February 2012 03:17 Go to previous messageGo to next message
t.contains3 <- c->collect(e | thisModule.createOne())
Re: Calling a rule a fixed number of times [message #808885 is a reply to message #808855] Tue, 28 February 2012 03:55 Go to previous messageGo to next message
Thank you very much Sylvain!
I have tested it and it works great!
I am wondering how to apply this for a Sequence of a Sequence. The real problem was that I have a reference which is a container of N elements:
Original rule
rule SylvainTheRuler {
    from
        s : ...
    to
        t : ... (
            container <- s.refers -- it is a reference to a Sequence of objects
If I apply your solution:
    from
        s : ...
    using {
        c : Sequence (Integer) = Sequence{1,2,3};
    to
        t : ... (
            container <- container <- c -> collect(e | thisModule.createOne(s.refers->first())),
It works really nice but only for the first element. How to do it for the whole Sequence s.refers?
PS: In fact, the length of c (the Sequence of integers) is different for each element of s.refers; the length is stored in each element of the sequence s.refers.
Thank you very much for your time and support,
Best regards
Re: Calling a rule a fixed number of times [message #808955 is a reply to message #808885] Tue, 28 February 2012 05:20 Go to previous messageGo to next message
        t : ... (
            container <- c -> collect(e | thisModule.createOne(s.refers->at(e))),
but you could directly do :
        t : ... (
            container <- s.refers -> collect(e | thisModule.createOne(e)),
Re: Calling a rule a fixed number of times [message #809105 is a reply to message #808955] Tue, 28 February 2012 08:39 Go to previous message
Thank you so much for your fast reply Sylvain.
It was not exactly what I meant in the problem, but I managed to solve it following the same philosophy of your solution.
Best regards and thank you very much.
Previous Topic:[qvto]failed to create object
Next Topic:[ATL]syntax source model
Current Time: Tue Nov 04 20:44:22 EST 2025
Powered by FUDForum. Page generated in 0.05757 seconds
