Home » Modeling » M2T (model-to-text transformation) » [Acceleo ]ECORE Loop over References
[Acceleo ]ECORE Loop over References [message #791862] Mon, 06 February 2012 05:46 Go to next message
my M2T templates are based on ECORE and I'd like to write a simple template the copies the values of an object into an array (php). To do so, I need the current index of the for loop. In Acceleo 2.x there was a a current() function, but I could not find anything similar in Acecleo 3.x
My template code looks like:
[for (ref : EReference | e.eReferences)]
$result['['/] X [']'/] = ... // TODO write instead of X the current index
[/for]
The result should look like
$result[0] = ...
$result[1] = ...
This gives me also an warning in the eclipse. Is teher a better way to loop over the refs? For the eAttributes this seems to be fine.
By the way, is there a smarter way to print "[" or "]"s?
THX,
Kalaus
[Updated on: Tue, 07 February 2012 04:00] by Moderator
Re: [Acceleo ]ECORE Loop over References [message #792678 is a reply to message #791862] Tue, 07 February 2012 04:17 Go to previous messageGo to next message
Current index: [i/]
[/for]
If you have a compilation issue with this, switch to 3.1.2 (a bug appeared with this in 3.1.1)
Since '[' is the only character that creates a problem, we choose not to introduce a combination to write it instead of ['['/] and we recommend to use the same for [']'/]
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo ]ECORE Loop over References [message #808012 is a reply to message #792678] Mon, 27 February 2012 04:45 Go to previous messageGo to next message
cool this works. But I still stumbled upon one other issue. If I want to loop over all eAttributes and the all eRefrences and write the values into an array, how would I do this the best way? Suppose I don not have an "append" method?
[for (ref : EAttribute | e.eAllAttributes)]
$result['['/] [i/] [']'/] = ... //
[/for]
$result['['/] X [']'/] = ... // so this should be e.eAllAttributes.size + i or so...
[/for]
Thanks a lot,
Klaus
Re: [Acceleo ]ECORE Loop over References [message #808021 is a reply to message #808012] Mon, 27 February 2012 04:50 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Kalaus,<br>
<br>
Note that you're using eAllAttributes in one case but not e<b>All</b>Reference
in the other so you'll only get the references defined locally in
the class, not the ones from super classes.<br>
<br>
<br>
On 27/02/2012 10:45 AM, Kalaus Schaefersen wrote:
<blockquote cite="mid:jifjbb$25o$1@news.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
[/for]
<br>
<br>
<br>
<br>
[/for]
<br>
<br>
<br>
Thanks a lot,
<br>
<br>
Klaus
<br>
<br>
<br>
</blockquote>
</body>
</html>
Re: [Acceleo ]ECORE Loop over References [message #808930 is a reply to message #791862] Tue, 28 February 2012 04:53 Go to previous message
Kalaus,
Do you really need to iterate through two different loops over attributes and references? You could use a loop on eAllStructuralFeatures instead and not worry about the index.
[for (feature : EStructuralFeature | e.eAllStructuralFeatures())]
[/for]
Laurent Goubet
Obeo
Previous Topic:[Acceleo] Errors running builder 'Acceleo Builder'
Next Topic:[Acceleo] trying to use eGet
Current Time: Sat Jul 26 09:02:19 EDT 2025
Powered by FUDForum. Page generated in 0.08458 seconds
