Home » Eclipse Projects » Eclipse Platform » rename all plugin's properties
rename all plugin's properties [message #79753] Sat, 21 June 2003 06:26 Go to next message
I have recently renamed the packages of my plugin, and
also renamed all project properties' qualified names.
What is the best way to update all properties which are already stored
to have the new names ?
I would like to iterate over all project's properties, find the ones
that start with the old name and rename them. However it seems that
iterating over all project's properties is not possible. Is there
another way around ?
Genady
Re: rename all plugin's properties [message #80799 is a reply to message #79753] Mon, 23 June 2003 12:08 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
There's no way to iterate over all of a project's properties (I assume
you mean either IResource session or persistent properties). You can
only interete over all resources (for example with IResourceVisitor),
and check each one for the desired property. In the case of session
properties, the resource proxy visitor allows you to do this in a very
efficient way... see IResourceProxyVisitor for more details. Apologies
if I misunderstood what you meant by "properties", it's a bit of an
overloaded term.
Genady wrote:
> Genady
Re: rename all plugin's properties [message #83397 is a reply to message #80799] Thu, 26 June 2003 17:15 Go to previous messageGo to next message
You understood me right. It looks like there is such option, but it's
just not an API. Am I right about it?
What did you (eclipse developers) do when you renamed the plugins?
Genady
> overloaded term.
> Genady wrote:
>> Hi,
>> Genady
Re: rename all plugin's properties [message #84397 is a reply to message #83397] Fri, 27 June 2003 18:19 Go to previous message
For the most part we have avoided renaming any plugins or property keys.
If we have done renaming, then we have had to add backwards
compatibility code to manually remove the old keys. Typically we will
use a metadata version stamp, so we can quickly check if the metadata
version number has changed, and then recompute from scratch or convert
as necessary. Yes, there are internal methods that do something
similar, but nothing in the API.
> Genady
>> Apologies if I misunderstood what you meant by "properties", it's a
>> bit of an overloaded term.
>> Genady wrote:
>>> Hi,
>>> stored to have the new names ?
>>> Genady
Previous Topic:IProject.setDescription throwing CoreException without any visible reason.
Next Topic:JRE redefinition launch error
Current Time: Fri Jul 25 00:50:26 EDT 2025
Powered by FUDForum. Page generated in 0.05503 seconds
