| Adding a "design label" to a link [message #80513] |
Thu, 23 November 2006 12:17  |
Originally posted by: joerg.weinmann.iese.fraunhofer.de
Hallo,
I would like to add a design label (non-readable, not-stored in the
domain) to a link. But it doesn't work for me. If I add a design label to
a node, everything works like I would expect.
So my question is: Is there a way to add a design label to a link or is
this not possible at the moment.
Jörg
| Re: Adding a "design label" to a link [message #80741 is a reply to message #80729] |
Fri, 24 November 2006 10:18   |
Ah, ok. I see.
A Label Mapping without a reference to a 'Feature' _is_ a design label.
Is there a difference between a design label of a node and a design label
of a connection?
For a design label of a node, I just added a label to the corresponding
figure in the gmfgraph file. I didn't need to reference the label to the
gmfmap file. I assumed that this is ok, because I already referenced the
node in the gmfmap. But for connections it seems to work differently?
Jörg
Dmitry Stadnik wrote:
> Yes, and it has design label as you've just asked.
> Jörg Weinmann wrote:
>> Thanks for your answer!
>> But I think the 'ship destination' link correspondens to EReference
>> destination in the ecore model. But I don't want to change my model, I
>> just want add a label to a link without changing the underlying model
>> file. Something like the 'Note' you can attach to every object. This is
>> not stored in the domain file, but in the diagram itself.
>>> I guess 'ship destination' link in TaiPan sample has the label you need.
>>>> Hallo,
>>>> label to a node, everything works like I would expect.
>>>> is this not possible at the moment.
>>>> Cheers,
>>>> Jörg
| Re: Adding a "design label" to a link [message #80749 is a reply to message #80741] |
Fri, 24 November 2006 10:30  |
Originally posted by: 5d5.mail.ru
Here it is: http://wiki.eclipse.org/index.php/GMF_Labels
> Ah, ok. I see. A Label Mapping without a reference to a 'Feature' _is_ a
> design label.
> label of a connection?
> Cheers,
> Jörg
>>> I just want add a label to a link without changing the underlying
>>> model file. Something like the 'Note' you can attach to every object.
>>> This is not stored in the domain file, but in the diagram itself.
>>>> need.
>>>>> Hallo,
>>>>> or is this not possible at the moment.
>>>>> Cheers,
>>>>> Jörg
FUDForum. Page generated in 0.05080 seconds
