Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.2 and JDK 1.6
TPTP 4.2 and JDK 1.6 [message #80562] Thu, 10 August 2006 12:51 Go to next message
Is the profiler supposed to work with JDK 1.6. I can't get it to work but
before I
give all the gory details I thought I'd make sure this combination is
currently
supported. Thanks.
Steve
Re: TPTP 4.2 and JDK 1.6 [message #80577 is a reply to message #80562] Thu, 10 August 2006 15:05 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0068F661852571C6_=
Content-Type: text/plain; charset="US-ASCII"
No TPTP 4.2 uses a JVMPI agent for profiling, which isn't supported in JDK
1.6. You'll need to downgrade to JDK 1.5 or 1.4.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">No TPTP 4.2 uses a JVMPI agent for profiling,
which isn't supported in JDK 1.6. &nbsp;You'll need to downgrade to JDK
1.5 or 1.4.</font>
<br><font size=2 face="sans-serif"><br>
Navid Mehregani</font>
--=_alternative 0068F661852571C6_=--
Re: TPTP 4.2 and JDK 1.6 [message #80637 is a reply to message #80577] Fri, 11 August 2006 14:02 Go to previous messageGo to next message
Thanks very much for the info. Actually, I think I'll just wait until TPTP
upgrades to Java 1.6
"Navid_Mehregani" <nmehrega@ca.ibm.com> wrote in message
news:ebg01f$l1p$1@utils.eclipse.org...
Navid Mehregani
Re: TPTP 4.2 and JDK 1.6 [message #80652 is a reply to message #80637] Fri, 11 August 2006 16:52 Go to previous messageGo to next message
--=_alternative 0072BDB7852571C7_=
No problem. Another thing you can do is download the JVMTI agent
available from our download page. The JVMTI agent should be compatible
with JDK 1.6. However, note that it's available as a technology preview,
which means it might not be as stable as agents included in the TPTP
driver.
Navid Mehregani
<br><font size=2 face="sans-serif">No problem. &nbsp;Another thing you
can do is download the JVMTI agent available from our download page. &nbsp;The
JVMTI agent should be compatible with JDK 1.6. &nbsp;However, note that
it's available as a technology preview, which means it <b>might </b>not
be as stable as agents included in the TPTP driver.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0072BDB7852571C7_=--
Re: TPTP 4.2 and JDK 1.6 [message #80709 is a reply to message #80652] Tue, 15 August 2006 02:31 Go to previous message
> preview, which means it *might *not be as stable as agents included in
> the TPTP driver.
> Navid Mehregani
Early tests we have done with Java 6 shows that our JVMTI profiler does
not currently support this environment (although it may work in certain
cases). Java 6 support is tracked under Bugzilla 148936.
Asaf
Asaf Yaffe
Eclipse TPTP Committer, Platform Project (JVMTI Profiler)
Previous Topic:AGR and Window Problem
Next Topic:AGR: Test case continuation in case of Verification Hook indicates a failure
Current Time: Fri Jul 18 18:20:04 EDT 2025
Powered by FUDForum. Page generated in 0.04583 seconds
