How to use MPartDescriptor [message #805968] |
Fri, 24 February 2012 06:02  |
I am not sure, but I think the EPartService API has changed from 4.1 to 4.2. At least I don't remember that in 4.1 this service already had the methods createSharedPart.
Anyway, I do know how to define an MPartDescriptor. In 4.1 an MPart for this descriptor was created with EPartService.createPart(id), where id is the identifier of the MPartDescriptor. This part can be found again with EPartService.findPart(id) -- if there is only one.
I don't know whether this is still the way to go with 4.2. The problem is, that one may need do create more than one MPart for one MPartDescriptor. An editor may be one example: one may want to edit different instances of one and the same kind.
Then one is not able to find the MPart corresponding to one particular instance with the id of the MPartDescriptor -- maybe there are more parts with the same id but with different "content". One way to go is using EPartService.getParts() which unfortunately will return all MParts, not only those corresponding to one particular MPartDescriptor. Then one would need to check, whether there is one MPart for the particular MPartDescriptor having a particular "content".
So something is missing that will find an MPart for a given MPartDescriptor with particular "content" or "reference".
My question is, whether MPlaceholder and EPartService.createSharedPart(id) fills this gap, and if so, how one would use it. If not, whether the way described above is the only way to go.
Re: How to use MPartDescriptor [message #805981 is a reply to message #805968] |
Fri, 24 February 2012 06:24   |
Am 24.02.12 12:02, schrieb Karl Weber:
You can create as many instance of MPart from an MPartDescriptor! It is
NOT a 1:1 relation - currently no relation between the both is created
which though might make sense to provide a EPartService method (see below).
As outlined there's no such 1:1 relation.
To mimic editors we planned to use MInputPart but because we current
don't have editor support at EAP the EPartService has no such method. We
could maybe add one in the M6 - please file a feature request.
One could think about an EPartService method to locate all
MPart-Instances created from an MPartDescriptor (e.g. we could store
this relation in the MPart#persistedState) => please file a feature request.
> go.
No MPlaceholder allows to share MUIElement instances between perspectives.
Tom
Re: How to use MPartDescriptor [message #806091 is a reply to message #805981] |
Fri, 24 February 2012 09:39  |
Tom Schindl wrote on Fri, 24 February 2012 12:24Am 24.02.12 12:02, schrieb Karl Weber:
Done
FUDForum. Page generated in 0.06960 seconds
