Contributing to any e4 Application [message #797397] |
Mon, 13 February 2012 07:38  |
Hi all,
I am trying to learn e4, but maybe I am biased by 3.x and need some clarifications.
In 3.x you can contribute (with a View, a Command or whatsoever) with a plug-in, without knowing nothing about which Application will benefit from your plugin, you just contribute to any application (maybe the IDE itself), as soon as your plugin is included into the launch/product.
In e4 I am finding several documentation pages that point out that you must, in the e4 Model Fragment, reference to the parentElementId that you want to contribute.
Is really this way or does exists a way in e4 to contribute like in 3.x in a more generic manner?
In this latter case how can I do it (could someone attach a minimal sample)?
Thank you very much
Vincenzo Caselli
Re: Contributing to any e4 Application [message #797511 is a reply to message #797397] |
Mon, 13 February 2012 10:28   |
There are 2 ways:
a) Fragment.e4xmi with the current drawback that you have to know the
parent you want to contribute to (enhancement request can on how
this could be overcome is here [1])
b) Use a Processor and create the contribution programmatically
c) A new option I just came up in this very second is that instead of
using XPath we could add one where you give the system a Java-Class
to identify the merge target
The nice thing about all current fragment solution is that one can
plug-in his/her own one because the merge into the target model is done
by the EMF-Element itself [see patch in 1] so implementing and using a)
/ c) does not require help/changes from the E4AP, what a clever design ;-)
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=324954
Am 13.02.12 13:38, schrieb Vincenzo Caselli:
> Hi all,
> clarifications.
> sample)?
> Thank you very much
> Vincenzo Caselli
Re: Contributing to any e4 Application [message #806128 is a reply to message #806088] |
Fri, 24 February 2012 10:18   |
The xpath contribution would be exactly this kind of thing - it would
allow you to contribute to ANY application.
In reality in 3.x you've been able to contribute only
views/editors/commands/handlers to any application - menus and others
who needed a ref-id have not been possible there as well.
So all that is missing is that you we provide a possibility to
contribute to the root-application element without using an id - you can
file a feature request if you want.
Tom
Am 24.02.12 15:39, schrieb Vincenzo Caselli:
> Tom, Lars,
> thank you for your answers!
> As a newby of E4 however I still have the feeling that 3.x has/had the
> incredible power of the combination between:
> 1) declarative (plugin.xml) contribution
> 2) contribution plugin can be used by any application (no ties with a
> "base" application = no 1->N relationship between
> application->contributions)
> I would not be misunderstood: I am eager to learn to work with E4 and I
> will encourage other to switch from 3.x. I am just trying to be sure we
> are not loosing something so great like the combination of the above
> points.
> Lars, I have read the tutorial "Eclipse 4 Modularity": very useful!
> Any link to other tutorials on how to do the same contribution for other
> things (parts, perspectives, menus, perspective extensions, preference
> pages, etc..) is greatly welcome!
> Thank you again
> Vincenzo
Re: Contributing to any e4 Application [message #1196365 is a reply to message #797511] |
Tue, 19 November 2013 06:31  |
Thomas Schindl wrote on Mon, 13 February 2012 10:28c) A new option I just came up in this very second is that instead of
Any example/docs of implementing this option?
And why target milestone of bug 324954 is set to 4.3 M4 when 4.3.1 still have no XPath feature implemented?
Michael.
[Updated on: Wed, 20 November 2013 00:33] by Moderator
FUDForum. Page generated in 0.26777 seconds
