Cannot Start Eclipse [message #805465] |
Thu, 23 February 2012 15:04  |
I am using Eclipse 3.3. I've been using it for a couple of years now. I went into a workspace dozens (hundreds) of time, and a few times today. Now, all of a sudden, the workspace will not load. It looks like it's going to, then it does not load. The error in the Eclipse log is:
!ENTRY com.google.gwt.eclipse.core 4 0 2012-02-23 14:57:25.507
!MESSAGE Could not start source viewer server.
!STACK 0
org.mortbay.util.MultiException[java.net.SocketException: Unrecognized Windows Sockets error: 0: JVM_Bind]
at org.mortbay.http.HttpServer.doStart(HttpServer.java:686)
at org.mortbay.util.Container.start(Container.java:72)
at com.google.gdt.eclipse.platform.jetty.JettyServer.start(JettyServer.java:73)
at com.google.gwt.eclipse.core.GWTPlugin.start(GWTPlugin.java:116)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:999)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:993)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:974)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:260)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:405)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:369)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:357)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at com.google.gdt.eclipse.suite.GdtPlugin.start(GdtPlugin.java:394)
I am completely stumped. Any help would be appreciated! Thanks!
Re: Cannot Start Eclipse [message #807047 is a reply to message #806092] |
Sat, 25 February 2012 18:05  |
Thanks for everybody's assistance! I have resolved the issue, so here's what I did:
I found the location of the current open files. It is in the [workspace folder\.metadata\.plugins\org.eclipse.ui.workbench folder in a file called workbench.xml. There is a tag called <editors>. Within this element is a series of <editor> elements that list all the currently open files (and information on what editor to use on these files). I removed all of these tags and relaunched Eclipse and it opened with a blank workbench. So my suspicion was correct, it was having troubles opening one of the files. It was confusing because it never threw an Eclipse log at all, so it was tough to debug.
Thanks for everyone's help; maybe this piece of info I've found will help someone else in the future!
[Updated on: Sat, 25 February 2012 18:07] by Moderator
FUDForum. Page generated in 0.24436 seconds
