.odp and .odt formats gives exception [message #800555] |
Fri, 17 February 2012 03:06  |
When I am trying to generate report in ODT and ODP format it gives me list of exception as below. Generated reports has no problem but exception are displayed on console while generating these reports. I have copied the below jars but still the problem persists.
org.eclipse.birt.report.engine.emitter.odp.config_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.odp_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.ods.config_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.ods_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.odt.config_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.odt_3.7.0.v20110602.jar
Please suggest how to resolve the below exceptions.
Feb 17, 2012 12:34:43 PM org.eclipse.birt.report.engine.odf.AbstractOdfEmitter save
SEVERE: Stream closed
java.io.IOException: Stream closed
at java.util.zip.ZipOutputStream.ensureOpen(Unknown Source)
at java.util.zip.ZipOutputStream.closeEntry(Unknown Source)
at org.eclipse.birt.report.engine.odf.pkg.Package.writeManifest(Package.java:188)
at org.eclipse.birt.report.engine.odf.pkg.Package.close(Package.java:120)
at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.save(AbstractOdfEmitter.java:166)
at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.end(AbstractOdfEmitter.java:143)
at org.eclipse.birt.report.engine.emitter.odt.OdtEmitter.end(OdtEmitter.java:602)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.end(CompositeContentEmitter.java:65)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:182)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at com.sneengineers.wims.reportGeneration.ReportCreation.main(ReportCreation.java:57)
Deepali.
FUDForum. Page generated in 0.07097 seconds
