Home » Archived » BIRT » BIRT bar chart report shutting down weblogic server(BIRT bar chart Weblogic )
BIRT bar chart report shutting down weblogic server [message #804544] Wed, 22 February 2012 14:01 Go to next message
We have a BIRT report with bar chart in it running fine in multiple app server environments. In one of our server, (Solaris - Weblogic 10.3), if I try to bring up this report, it kills the application server. We have narrowed down this to a variable set in the environment where we are starting Weblogic.
DISPLAY=localhost:10.0.
If we remove this env variable, everything seems to be fine.
The only error message I can see is
"X connection to localhost:10.0 broken (explicit kill or server shutdown)."
This is a product which will be installed at multiple client locations and I may not be able to tell them to take out the DISPLAY variable. Is there any setting in BIRT which I can use to fix this issue?
Any help is much appreciated!
Re: BIRT bar chart report shutting down weblogic server [message #805076 is a reply to message #804544] Thu, 23 February 2012 04:56 Go to previous messageGo to next message
have u implemented birt in zend with the help of zend javabridge . if so can u help me on that ...
Re: BIRT bar chart report shutting down weblogic server [message #805236 is a reply to message #805076] Thu, 23 February 2012 09:31 Go to previous messageGo to next message
Sorry. Haven't. What we have is BIRT engine integrated with a J2ee app.
Re: BIRT bar chart report shutting down weblogic server [message #805434 is a reply to message #804544] Thu, 23 February 2012 14:11 Go to previous messageGo to next message
Take a look at this link:
http://wiki.eclipse.org/BIRT/FAQ/Charts2.2#Charts_not_rendering_on_Unix_systems
Jason
On 2/22/2012 2:01 PM, Shaju J wrote:
> Hello,
> starting Weblogic.
Re: BIRT bar chart report shutting down weblogic server [message #805442 is a reply to message #805434] Thu, 23 February 2012 14:28 Go to previous messageGo to next message
Thanks Jason for the reply. Will give it a try
Re: BIRT bar chart report shutting down weblogic server [message #805489 is a reply to message #805442] Thu, 23 February 2012 15:45 Go to previous message
Thank you Jason. That worked like a charm. Saved the day!!
Previous Topic:Image from MIME encoded database record
Next Topic:Linkage Error Seam, JBoss, BIRT
Current Time: Sat Jul 26 02:57:28 EDT 2025
Powered by FUDForum. Page generated in 0.04992 seconds
