Home » Eclipse Projects » Remote Application Platform (RAP) » Implement Sorter/Comparator with VirtualTable and DeferredContentProvider
Implement Sorter/Comparator with VirtualTable and DeferredContentProvider [message #80077] Mon, 31 March 2008 03:46 Go to next message
Hello Guys,
I am having trouble implementing a sorter with a VirtualTable and a
content provider which either extends from DeferredContentProvider or
implements ILazyContentProvider.
The problem is the compare method of the defined sorter never gets
invoked with ILazyContentProvider. I put some debug statements and on
clicking on Columnheader I get as far as setting the sort direction and
also setting the Sorter for that column but the compare of the
Sorter(which extends ViewerComparator) never gets invoked even when the
viewer is refreshed.
Please help me out with Ideas/Examples.
Also, if there are examples make it for more than one column in the
table. The single column examples out on the web are very confusing and
don't work for multiple columns.
Arpit
Re: Implement Sorter/Comparator with VirtualTable and DeferredContentProvider [message #80095 is a reply to message #80077] Mon, 31 March 2008 03:58 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
See the excerpt of the TableViewer JavaDoc:
* As of 3.1 the TableViewer now supports the SWT.VIRTUAL flag. If the
* underlying table is SWT.VIRTUAL, the content provider may implement
* {@link ILazyContentProvider} instead of {@link
IStructuredContentProvider}.
* Note that in this case, the viewer does not support sorting or
filtering.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Arpit Desai [mailto:arpitdesai23@gmail.com]
Bereitgestellt: Montag, 31. März 2008 09:46
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Implement Sorter/Comparator with VirtualTable and
Betreff: Implement Sorter/Comparator with VirtualTable and
Hello Guys,
Arpit
Re: Implement Sorter/Comparator with VirtualTable and DeferredContentProvider [message #80140 is a reply to message #80095] Mon, 31 March 2008 04:14 Go to previous messageGo to next message
Frank is right. In 3.2 we didn't support filtering/sorting in case of
VIRTUAL-Tables no matter which content-provider you used. As of 3.3 we
only support sorting/filtering when using a IStructuredContentProvider
because the viewer and sorter implementation assumes to have the
complete model available.
If you are doing everything lazily you need to implement this your own,
sorry. If you have an idea how to implement it for lazy cases we are
open to discuss it because it is an often requested feature.
Tom
Frank Appel schrieb:
> filtering.
> Ciao
> Frank
> Hello Guys,
> Arpit
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Implement Sorter/Comparator with VirtualTable and DeferredContentProvider [message #80392 is a reply to message #80140] Mon, 31 March 2008 11:10 Go to previous messageGo to next message
Hello Frank/Tom,
Thanks for replying to my message. I had missed the "Note" on Java-docs,
honestly.
Tom,
I am keen on sorting the visible section of elements at-least, is this
possible using DeferredContentProvider and BackgroundContentProvider ?
I was going through the implementation in class
BackgroundContentProvider and it looked doable.
In my project I had MyContentProvider extend from
DeferredContentProvider and the model object implement IConcurrentModel
interface, however, I did not understand the flow of control in this
scenario.
If this type of sorting is supported with RAP 1.0 than please give me an
example to understand it.
Thank you again,
Arpit
> Tom
>> Hi,
>> filtering.
>> Ciao
>> Frank
>> Hello Guys,
>> Thanks,
>> Arpit
Re: Implement Sorter/Comparator with VirtualTable and DeferredContentProvider [message #80527 is a reply to message #80392] Tue, 01 April 2008 03:26 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
regarding your question if this works with RAP 1.0: the
DeferredContentProvider and friends are plain copies from the 3.3
RCP-JFace code and thus should work as their original counterpart.
The underlying Table widget received many bug fixes over the last
months. Therefore I recommend using the most recent milestone (1.1
M2) or even better CVS HEAD.
Rüdiger
Arpit Desai wrote:
> Hello Frank/Tom,
> honestly.
> Tom,
> scenario.
> Thank you again,
> Arpit
>> own, sorry. If you have an idea how to implement it for lazy cases we
>> are open to discuss it because it is an often requested feature.
>> Tom
>>> Hi,
>>> filtering.
>>> Ciao
>>> Frank
>>> Hello Guys,
>>> Thanks,
>>> Arpit
Re: Implement Sorter/Comparator with VirtualTable and DeferredContentProvider [message #80703 is a reply to message #80527] Tue, 01 April 2008 11:19 Go to previous message
Ok Thanks Rudiger, I will take the latest from CVS-HEAD.
Arpit
Rüdiger Herrmann wrote:
> RCP-JFace code and thus should work as their original counterpart. The
> underlying Table widget received many bug fixes over the last months.
> Therefore I recommend using the most recent milestone (1.1 M2) or even
> better CVS HEAD.
> Cheers,
> Rüdiger
> Arpit Desai wrote:
>> Hello Frank/Tom,
>> Java-docs, honestly.
>> Tom,
>> IConcurrentModel interface, however, I did not understand the flow of
>> control in this scenario.
>> an example to understand it.
>> Thank you again,
>> Arpit
>>> we only support sorting/filtering when using a
>>> IStructuredContentProvider because the viewer and sorter
>>> implementation assumes to have the complete model available.
>>> Tom
>>>> Hi,
>>>> filtering.
>>>> Ciao
>>>> Frank
>>>> Hello Guys,
>>>> Thanks,
>>>> Arpit
Previous Topic:Custom JavaScript code gets loaded but not executed
Next Topic:When is the ExpandBar component available?
Current Time: Sun Aug 31 03:30:04 EDT 2025
Powered by FUDForum. Page generated in 0.03751 seconds
