Home » Modeling » M2T (model-to-text transformation) » [acceleo] best way to pass extra data from Java to template ?
[acceleo] best way to pass extra data from Java to template ? [message #805035] Thu, 23 February 2012 04:09 Go to next message
I have a compiler that uses acceleo for its backend part. Currently, all data given to the templates from the java code are parameters of templates. Problem is that when I want to drive a nested template from my java code, I need to change all intermediate templates to have the needed extra parameter. This is ok for q&d prototype, but clearly not a good idea for the longterm Smile
What would be the best choice ?
Using properties is an option, but AFAIK, acceleo has support for loading properties from a file. I would need first to write my properties to a file and then load it from acceleo... Or I could extend property handling in acceleo.
I could also use a "java service" to query global properties.
Are there any other option ? What would you recommend ?
Marc
Re: [acceleo] best way to pass extra data from Java to template ? [message #805202 is a reply to message #805035] Thu, 23 February 2012 08:32 Go to previous message
I'm not sure I understood your need perfectly but the Acceleo properties files APIs let you load properties directly thanks to a "java.util.Properties". For that, have a look at the method "getPropertiesLoaderService(...)" in the generated Java launcher and look at "alternatePropertiesLoading(String)". This operation will receive the "id" of the properties files that you have registered in the getProperties(...) operation in the generated Java launcher and with this "id" it will look for the ".properties" file and load its content in a java.util.Properties object. You can plug your code here to load programmatically a java.util.Properties object without having any ".properties" file on your file system.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Previous Topic:JET presentations not accesible?
Next Topic:[XPand2] setting local variables
Current Time: Sat Jul 26 02:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.04983 seconds
