Home » Archived » BIRT » How to integrate birt in Zend Ce with the help of Zend JavaBridge without tomcat server?(integrating birt with zend with the help of zend javabridge)
How to integrate birt in Zend Ce with the help of Zend JavaBridge without tomcat server? [message #805070] Thu, 23 February 2012 04:52 Go to next message
i have googled to find any implementations of birt integration in zend framework with birt reporting but found none .
i have installed Zend JavaBridge and tested it by running a java program succesfully
has shown in this link below ..
files.zend.com/help/Zend-Server/working_with_the_java_bridge.htm
when i try to run any of the birts sample report
given in the link below ..
files.zend.com/help/Zend-Platform-i5/birt_apis.htm
it shows internal server error
can anyone show me how to run a birt report in zend CE with the help of Zend java bridge using tomcat server is not an option for me .
please help me has anyone implemented it ? Sad
Re: How to integrate birt in Zend Ce with the help of Zend JavaBridge without tomcat server? [message #806287 is a reply to message #805070] Fri, 24 February 2012 14:47 Go to previous messageGo to next message
Justin
If you download the 3.7 runtime you should be able to build a command
line app that runs the reports. Attached is a simple example. To build
the class make sure you have the jars from the runtime
download/reportengine/lib directory in the classpath. Once built you
should be able to call it the same way as the simple Java app. This
sample does a platform startup and shutdown which is generally not a
good idea if you are going to generate a lot of reports. A better
solution is to wrap the Platform startup and report engine creation in a
singleton that starts when you server starts up, then use the engine to
create a new task per request.
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.impl.RunAndRenderTask;
import org.eclipse.birt.report.engine.api.script.IReportContext;
public class RunAndRenderTaskTest {
public void runReport() throws EngineException
RunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
//config.setLogConfig("c:/dwn", Level.SEVERE);
//config.setResourcePath("C:/work/workspaces/3.7.1workspaces/BIRT
Metal/APIs/resources");
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/testlibrary.rptdesign");
task = (RunAndRenderTask) engine.createRunAndRenderTask(design);
IReportContext irc = task.getReportContext();
//task.setParameterValue("Top Count", (new Integer(5)));
//task.validateParameters();
//HTMLRenderOption options = new HTMLRenderOption();
//options.setImageDirectory("./");
//options.setOutputFileName("output/resample/external.html");
//options.setOutputFormat("html");
//options.setEmbeddable(false);
//options.setEnableMetadata(true);
//options.setEnableInlineStyle(false);
//options.setEnableAgentStyleEngine(true);
//options.setEnableCompactMode(true);
//PDFRenderOption options = new PDFRenderOption();
//options.setOutputFileName("output/resample/hidefooter.pdf");
//options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
//options.setOutputFormat("pdf");
//EXCELRenderOption options = new EXCELRenderOption();
//options.setOutputFormat("xls");
//options.setOutputFileName("output/resample/customers.xls");
//options.setWrappingText(true);
//options.setImageHandler(new HTMLServerImageHandler());
options.setSupportedImageFormats("JPG;PNG;BMP;SVG;GIF");
options.setOutputFileName("output/resample/testlibrary.html");
//options.setOutputFormat("ppt");
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTaskTest ex = new RunAndRenderTaskTest( );
ex.runReport();
System.exit(0);
catch ( Exception e )
e.printStackTrace();
Jason
> succesfully
> please help me has anyone implemented it ? :(
Re: How to integrate birt in Zend Ce with the help of Zend JavaBridge without tomcat server? [message #807891 is a reply to message #806287] Mon, 27 February 2012 00:57 Go to previous message
Thanks for your reply jason i will surely try it ... Smile
Previous Topic:Add font to BirtViewerApp
Next Topic:how to create tree table in bird
Current Time: Wed Jul 23 18:38:40 EDT 2025
Powered by FUDForum. Page generated in 0.28200 seconds
