Home » Modeling » TMF (Xtext) » Editor -> Compiler(How to convert a DSL editor/generator in standalone compiler.)
Re: Editor -> Compiler [message #804590 is a reply to message #804506] |
Wed, 22 February 2012 15:02   |
Thanks Ed,
comments below.
Mauro
On 22/02/2012 18:55, Ed Willink wrote:
> Hi
> a) doesn't the builder do it automatically interactively?
Of course, but what I'm looking for is a kind of command-line tool which
should accept a list of DSL files as arguments and produce the generated
files in a suitable dir (either "$(pwd)/src-gen" or "-o whatever"),
possibly taking care of creation of a "Xtext project", if needed.
> b) run your XXXStandaloneSetup.doSetUp(), create an XXXResource from
> your text and that will at least do the compile
Can You elaborate, please?
Should I write a "static main()" to create an SIDLResource and then call
SIDELStandaloneSetup.doSetUp()?
Is that all?
> c) if you want small, the ANTLr is huge
I know, but it's much smaller than a complete eclipse installation,
especially if you consider I would need EMF, Xtext, Xtend, ...
> The Xtext model is EBNF with model-annotations that appears to be rather
> easy to translate into LALR, so I'm currently developing QVTo and
> Acceleo transformations from Xtext to LPG; initially just to get a solid
> check that my grammar is not exploiting backtracking, but eventually to
> get a 10-fold saving in code size and a 2-fold improvement in speed.
I'm looking for something easyly derivable from my current code (which
is working well).
> Regards
> Ed Willink
> On 22/02/2012 13:55, Mauro Condarelli wrote:
>> Hi,
>> I have a plugin (XText/XTend)I use to edit my DSL and generate some
>> code form it each time one DSL file is saved.
>> So far, so good.
>> Now that it seems OK I would like to have also a command-line utility
>> to "compile" a [set of] DSL files.
>> No editing capability.
>> No graphics.
>> Possibly small.
>> Is something like that possible, somehow (without rewriting everything)?
>> TiA
>> Mauro
Re: Editor -> Compiler [message #804601 is a reply to message #804506] |
Thanks Ed,
comments below.
Mauro
> Hi
Is that all?
is working well).
> Regards
> Ed Willink
>> Hi,
>> So far, so good.
>> No graphics.
>> Possibly small.
>> TiA
>> Mauro
Re: Editor -> Compiler [message #804665 is a reply to message #804590] |
Wed, 22 February 2012 16:44   |
> Is that all?
The other way around. SIDELStandaloneSetup.doSetUp() ensures that Xtext
support is registered for *.sidel files, so that a ResourceSet will
automatically create an Xtext Resource from a text stream.
You won't easily get rid of EMF (or Xtend). Xtext might be optional for
compile-only.
> is working well).
My aim is to exploit Xtext for editors and re-use the grammar for a more
compact LPG-based parser. You would just add an 'LpgParserFragment' to
your MWE workflow so that your Xtext grammar is converted to an LPG
parser. Don't wait for it.
Ed Willink
Re: Editor -> Compiler [message #804947 is a reply to message #804590] |
Thu, 23 February 2012 02:06  |
Am 2/22/12 9:02 PM, schrieb Mauro Condarelli:
> Thanks Ed,
> comments below.
> Regards
> Mauro
>> Hi
There no such command line tool, but it's generally possible to build one.
For that you need to
1) create an injector using the StandaloneSetup (as Ed suggested),
2) obtain a ResourceSet from the created injector,
3) obtain an instance of IGenerator
4) -"- and instance of IFileSystemAccess
5) load the models you want to generate code for into the resourceset
6) invoke the generator using the resources and the file system access
I might have forgotten something. Just ask if you got stuck.
Also if you are able to generalize this a bit we are happy to accept
contributions :-)
Sven
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Current Time: Wed Jul 23 20:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.07536 seconds
