Home » Eclipse Projects » Eclipse Platform » Eclipse Error(An error has occurred. See the log file)
Eclipse Error [message #804439] Wed, 22 February 2012 11:22 Go to next message
Eclipse
<Path to log file>
OK
Well I don't know what happened but when I start eclipse I get the error above. Attached is the log file
  • Attachment: .log
    (Size: 381.15KB, Downloaded 496 times)
Re: Eclipse Error [message #804580 is a reply to message #804439] Wed, 22 February 2012 15:00 Go to previous messageGo to next message
Sorry Jonathan, but probably nobody will read 5000+ lines long log... I just see on the first few lines OutOfMemoryException. You have to minimize and isolate issue.
What version of Eclipse are you running, what are conditions and scenario to reproduce error, etc. etc.
Re: Eclipse Error [message #804581 is a reply to message #804439] Wed, 22 February 2012 15:00 Go to previous messageGo to next message
Re: Eclipse Error [message #804582 is a reply to message #804439] Wed, 22 February 2012 15:01 Go to previous messageGo to next message
icon3.gif  Re: Eclipse Error [message #804583 is a reply to message #804439] Wed, 22 February 2012 15:02 Go to previous messageGo to next message
Re: Eclipse Error [message #804586 is a reply to message #804439] Wed, 22 February 2012 15:04 Go to previous messageGo to next message
Re: Eclipse Error [message #804587 is a reply to message #804439] Wed, 22 February 2012 15:04 Go to previous messageGo to next message
Re: Eclipse Error [message #804588 is a reply to message #804439] Wed, 22 February 2012 15:00 Go to previous messageGo to next message
Re: Eclipse Error [message #804589 is a reply to message #804439] Wed, 22 February 2012 15:00 Go to previous messageGo to next message
Re: Eclipse Error [message #804596 is a reply to message #804439] Wed, 22 February 2012 15:00 Go to previous messageGo to next message
Re: Eclipse Error [message #804597 is a reply to message #804439] Wed, 22 February 2012 15:01 Go to previous messageGo to next message
Re: Eclipse Error [message #804598 is a reply to message #804439] Wed, 22 February 2012 15:02 Go to previous messageGo to next message
Re: Eclipse Error [message #804599 is a reply to message #804439] Wed, 22 February 2012 15:04 Go to previous messageGo to next message
Re: Eclipse Error [message #804600 is a reply to message #804439] Wed, 22 February 2012 15:04 Go to previous messageGo to next message
Re: Eclipse Error [message #804676 is a reply to message #804582] Wed, 22 February 2012 17:02 Go to previous messageGo to next message
Well the steps are easy.
1) Open Eclipse
I'm running
Version: 3.7.0
Build id: I20110613-1736
I had to make a new workspace to get eclipse to open. I also have PLENTY OF MEMORY
Re: Eclipse Error [message #805113 is a reply to message #804676] Thu, 23 February 2012 05:49 Go to previous messageGo to next message
Okay, in this case I suggest that your workspace and/or Eclipse biniaries are corrupted. Delete ~/.eclipse/, your Eclipse installation and workspoace directory.
Re: Eclipse Error [message #805459 is a reply to message #805113] Thu, 23 February 2012 14:58 Go to previous messageGo to next message
Well what I had to do was rename the workspace folder (I had it set to auto-use my old/broken workspace) then it made a new workspace. I just imported the old projects and eclipse works fine now Cool
Re: Eclipse Error [message #988283 is a reply to message #804439] Thu, 29 November 2012 04:32 Go to previous message
simple solution is
better uninstall jdk 7 u 9 completely
and install jdk 7 u 7.
and it worked fine with eclipse juno.
Previous Topic:How to disable socks proxy ?
Next Topic:Assign Default Superclass for a Package
Current Time: Tue Jul 08 02:05:02 EDT 2025
Powered by FUDForum. Page generated in 0.37734 seconds
