Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » dltk source coding format template
dltk source coding format template [message #6606] Tue, 19 June 2007 11:33 Go to next message
do you guys have a source formatter template that you are using?
i'm not a fan of the indent, etc style, so i'd like to be able to
reformat the code in a manner that is easier for me, yet change it back
when i submit patches for things so i don't generate huge diffs making
revision history useless.
thx!
-jae
Re: dltk source coding format template [message #6626 is a reply to message #6606] Fri, 22 June 2007 00:03 Go to previous messageGo to next message
> thx!
We don't have any special infrastructure for formaters yet. But you add
JFace based formatting strategy. For not we have formatting only in
JavaScript( JavaScriptFormattingStrategy class ).
You could obtain JavaScript plugins from Eclipse DLTK repository.
Andrei.
Re: dltk source coding format template [message #6678 is a reply to message #6626] Fri, 22 June 2007 12:09 Go to previous messageGo to next message
On 2007-06-22 00:03:40 -0400, Andrei Sobolev <andrei.sobolev@xored.com> said:
>> thx!
> Andrei.
i think you missed what i was asking.....
i'm looking for a coding template for the dltk sources themselves, so
that if i submit a patch for something, i can make sure it's been
formatted according to whatever standards you use. basically something
that hooks into eclipse's source formatting framework.
there are lots of times i'm going through some piece of code and i
find it hard to follow b/c of the formatting, so i reformat it w/ my
standard. if i fix a bug or add fuctionality, etc - i don't want to
submit a patch w/ my formatting changes b/c it makes the diffs useless.
-jae
Re: dltk source coding format template [message #8045 is a reply to message #6678] Mon, 25 June 2007 00:01 Go to previous message
>>> back when i submit patches for things so i don't generate huge diffs
>>> making revision history useless.
>>> thx!
>> add JFace based formatting strategy. For not we have formatting only
>> in JavaScript( JavaScriptFormattingStrategy class ).
>> Andrei.
> there are lots of times i'm going through some piece of code and i find
Actually, we use default Eclipse formatting.
Previous Topic:DTLKCore.DEBUG
Next Topic:How do I configure the Ruby Runtime for TestCases
Current Time: Fri Aug 29 06:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.08790 seconds
