Home » Language IDEs » PHP Development Tools (PDT) » Xdebug, view full variable content
Xdebug, view full variable content [message #80382] Tue, 16 September 2008 17:34 Go to next message
HI when running the debugger, all of the variable contents are truncated
how can I set this to no limit?, to actually see the whole thing?
Re: Xdebug, view full variable content [message #80399 is a reply to message #80382] Tue, 16 September 2008 17:40 Go to previous messageGo to next message
There isn't an option to set "no limit" but you can increase the limit
within the XDebug config. Within Eclipse go to Window -> Preferences ->
PHP -> Debug -> Installed Debuggers. Highlight XDebug and click
"Configure". Within the window that pops up you can see the array depth
and the max children. Setting those values higher will give you more
data back about your variables.
If you are needing information on a specific element within a variable
array then it is sometimes better to watch that specific element without
trying to get the whole array. If you go to Window -> Show View ->
Expressions you can see your watched expressions. Then you can add an
expression there or within your code you can highlight the variable call
and right click -> watch to add it to your watched expressions.
Shawn Clark
Re: Xdebug, view full variable content [message #80413 is a reply to message #80382] Tue, 16 September 2008 17:56 Go to previous messageGo to next message
You currently cannot control the max data of xdebug through PDT (1.0.3 or upcoming 2.0 version)
which is the maximum amount of information an individual element will receive from xdebug in general.
However you can retrieve the whole value of a string. Select the variable you want to look in the
variables view and being up the context menu for it . Select "Change Value". This will bring up a
dialog box that will show you the full contents of the string. Press Cancel to ensure you don't
change the contents.
Dave Kelsey
Re: Xdebug, view full variable content [message #80429 is a reply to message #80413] Tue, 16 September 2008 18:43 Go to previous messageGo to next message
I tried Change Content once, and it was truncated as well (Im trying to
retrieve a long xml document)
> or upcoming 2.0 version) which is the maximum amount of information an
> variable you want to look in the variables view and being up the context
> menu for it . Select "Change Value". This will bring up a dialog box
> ensure you don't change the contents.
> Dave Kelsey
>> truncated how can I set this to no limit?, to actually see the whole
>> thing?
Re: Xdebug, view full variable content [message #80444 is a reply to message #80429] Wed, 17 September 2008 05:31 Go to previous messageGo to next message
How big is the string ? It would be interesting to know where the limitation is, whether it is
xdebug, the PDT code or the eclipse dialog box used to display it.
It would also be good if you could try PDT 2.0. I changed the string implementation in PDT to
display the current length stored in PDT the actual length of the string and the ability to get a
byte view of the string.
Dave Kelsey
>> Dave Kelsey
>>> thing?
Re: Xdebug, view full variable content [message #513997 is a reply to message #80444] Thu, 11 February 2010 18:56 Go to previous message
the "change value" works for me, thanks!
If this doesn't work for you, be sure you have xdebug setting xdebug.var_display_max_data set to an appropriate value, see http://xdebug.org/docs/all_settings
Previous Topic:Button Clicks Don't Work
Next Topic:Debugger redirections
Current Time: Thu Sep 18 05:40:36 EDT 2025
Powered by FUDForum. Page generated in 0.03488 seconds
