birt report java script problem in chrome and firefox [message #802813] |
Mon, 20 February 2012 08:44  |
I have downloaded an example of collapse/expand table rows using java script in birt from devshare . It is attached to this post . But this example is not working in mozilla firefox and chrome its showing error
'document.getElementById(btnstr) is null' in mozilla firefox.
'uncaught TypeError: Cannot set property 'value' of null' in chrome
although it works fine in IE and in eclipse IDE birt viewer.
I want to use this functionality in my report also
Please help
Rahul Deshpande
Re: birt report java script problem in chrome and firefox [message #815526 is a reply to message #815023] |
Wed, 07 March 2012 14:25   |
Ok I believe your issue is that your are using the run mapping instead
of frameset. You are using the script tag to hide a table before it is
actually making it to the browser:
<INPUT Type="BUTTON" name=<VALUE-OF>"mybutton"+row["parent"]</VALUE-OF>
id= <VALUE-OF>"mybutton"+row["parent"]</VALUE-OF> Value="-"
onClick="hidetable(this.form,
'<VALUE-OF>row["parent"]</VALUE-OF>','<VALUE-OF>row["Aggregation_2"]</VALUE-OF>');"></INPUT>
<VALUE-OF>row["Parentname"]</VALUE-OF> :
<VALUE-OF>row["parent_role"]</VALUE-OF>
<script>
hidetable( this.form, '<VALUE-OF>row["parent"]</VALUE-OF>',
'<VALUE-OF>row["Aggregation_2"]</VALUE-OF>' );
</script>
Remove this:
<script>
</script>
and put the following script on the table detail rows onrender
this.getStyle().display = "none";
Put that same script on the onrender for the group header row containing
the "parent" column. Also I changed your input tag to look like:
<form >
onClick='hidetable(this.form,
<VALUE-OF>row["parent"]</VALUE-OF>,<VALUE-OF>row["Aggregation_2"]</VALUE-OF>);'></INPUT>
</form>
I tried to run your report and it timed out on the connection, but I was
able to reproduce the issue with my sample and then fix it. Attached
are your design that I modified and the my modified sample report.
Jason
On 3/7/2012 1:08 AM, rahul rahuldeshpande89@gmail.com wrote:
> as per your suggestion i am posting html.
> when we load the page all rows should be hidden.
> i am attaching two files .
> 1.test.html contains only html
> 2. Call_Report_activity.rptdesign
> please use following link to run the report
> replace localhost and port number as per your environment.
> userid& Uid are parameters i am passing to report. i am using apache tomcat to run the report .
> localhost:8888/birt/run?__report=Call_Report_activity.rptdesign&UserId=NmMwY2I5NTUtY2QxZC1kYzg0LTA1MTMtNGU1YjRlZDQ0ZTcw&__overwrite=true&Uid=6c0cb955-
> cd1d-dc84-0513-4e5b4ed44e70
> If your runing report in IDE then you will be promted for UserId please enter value for it as 'NmMwY2I5NTUtY2QxZC1kYzg0LTA1MTMtNGU1YjRlZDQ0ZTcw'.
> Rahul
Attachment: Examples.zip
(Size: 23.93KB, Downloaded 294 times)
FUDForum. Page generated in 0.32494 seconds
