Home » Archived » BIRT » .odp and .odt formats gives exception(Generated reports has no problem but exception are comes on console while generating report.)
.odp and .odt formats gives exception [message #800555] Fri, 17 February 2012 03:06 Go to next message
When I am trying to generate report in ODT and ODP format it gives me list of exception as below. Generated reports has no problem but exception are displayed on console while generating these reports. I have copied the below jars but still the problem persists.
org.eclipse.birt.report.engine.emitter.odp.config_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.odp_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.ods.config_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.ods_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.odt.config_3.7.0.v20110602.jar
org.eclipse.birt.report.engine.emitter.odt_3.7.0.v20110602.jar
Please suggest how to resolve the below exceptions.
Feb 17, 2012 12:34:43 PM org.eclipse.birt.report.engine.odf.AbstractOdfEmitter save
SEVERE: Stream closed
java.io.IOException: Stream closed
	at java.util.zip.ZipOutputStream.ensureOpen(Unknown Source)
	at java.util.zip.ZipOutputStream.closeEntry(Unknown Source)
	at org.eclipse.birt.report.engine.odf.pkg.Package.writeManifest(Package.java:188)
	at org.eclipse.birt.report.engine.odf.pkg.Package.close(Package.java:120)
	at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.save(AbstractOdfEmitter.java:166)
	at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.end(AbstractOdfEmitter.java:143)
	at org.eclipse.birt.report.engine.emitter.odt.OdtEmitter.end(OdtEmitter.java:602)
	at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.end(CompositeContentEmitter.java:65)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:182)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
	at com.sneengineers.wims.reportGeneration.ReportCreation.main(ReportCreation.java:57)
Deepali.
Re: .odp and .odt formats gives exception [message #801014 is a reply to message #800555] Fri, 17 February 2012 15:22 Go to previous messageGo to next message
Can you post your code?
Jason
On 2/17/2012 3:06 AM, Deepali Patil wrote:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> Deepali.
Re: .odp and .odt formats gives exception [message #801299 is a reply to message #801014] Sat, 18 February 2012 01:28 Go to previous messageGo to next message
Thanks for reply.
Please find attached file for code.
Deepali.
Re: .odp and .odt formats gives exception [message #803631 is a reply to message #801299] Tue, 21 February 2012 10:48 Go to previous messageGo to next message
Can you try to close the task after you run the report?
task.run();
task.close();
Jason
On 2/18/2012 1:28 AM, Deepali Patil wrote:
> Thanks for reply.
> Deepali.
Re: .odp and .odt formats gives exception [message #804011 is a reply to message #803631] Tue, 21 February 2012 23:48 Go to previous messageGo to next message
Thanks for the reply,
I added task.close() in my code but exception still occurs for odp and odf format.
Please suggest something which resolve this exception.
Feb 22, 2012 10:10:44 AM org.eclipse.birt.report.engine.emitter.odp.OdpEmitter save
	at org.eclipse.birt.report.engine.emitter.odp.OdpEmitter.save(OdpEmitter.java:87)
	at org.eclipse.birt.report.engine.emitter.odp.OdpEmitter.end(OdpEmitter.java:63)
	at org.eclipse.birt.report.engine.nLayout.LayoutEngine.end(LayoutEngine.java:345)
	at com.sne.reportRunner.reportCreator.ReportGeneratorImpl.generateReport(ReportGeneratorImpl.java:95)
	at com.sne.reportRunner.reportCreator.ReportGeneratorImplTest.testThatReportInExcelFormatFileIsGenerated(ReportGeneratorImplTest.java:83)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
	at org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74)
	at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
	at org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82)
	at org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72)
	at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:231)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
	at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
	at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
	at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:174)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:46)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Deepali.
Re: .odp and .odt formats gives exception [message #804382 is a reply to message #804011] Wed, 22 February 2012 10:08 Go to previous messageGo to next message
Is it possible in your app that two threads are writing to the same
output file?
Jason
On 2/21/2012 11:48 PM, Deepali Patil wrote:
> odf format.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Deepali.
Re: .odp and .odt formats gives exception [message #804485 is a reply to message #804382] Wed, 22 February 2012 12:27 Go to previous messageGo to next message
Thanks for reply,
I am generating output report with generating random file name, therefore no possibility of writing to the same output report file.
final String outputFile = outputFileNameGenerator.getOutputFileNameFor(
Integer.toString(reportId) + "." + outputFormat);
I am not getting where I am going wrong.
Please help me to sort out this exception.
Deepali.
Re: .odp and .odt formats gives exception [message #804511 is a reply to message #804485] Wed, 22 February 2012 13:07 Go to previous messageGo to next message
Can you reproduce the issue with a command line app that I can run?
Jason
On 2/22/2012 12:27 PM, Deepali Patil wrote:
> Thanks for reply,
> Thanks, Deepali.
Re: .odp and .odt formats gives exception [message #804930 is a reply to message #804511] Thu, 23 February 2012 01:38 Go to previous messageGo to next message
I have attached an application which creates a report which you can run through command line.
This application is created using maven.
Changes that you need to do to run the application.
1) In pom.xml set <birt.runtime.location> to the lib of ReportEngine.
Run the application on command prompt using maven. On command prompt go to the folder where you have copied attached files. Run the below command
report-runner>mvn clean eclipse:clean eclipse:eclipse install
It will build successful but with exception.
Please go through my code.
Deepali.
Re: .odp and .odt formats gives exception [message #805502 is a reply to message #804930] Thu, 23 February 2012 15:59 Go to previous messageGo to next message
Can you compare your POM to the one in this thread:
http://www.birt-exchange.org/org/forum/index.php/topic/24196-mavenizing-birt-3-7-1/page__s__22a7ecc0cee225f7eb3ac8c3399c5491
Jason
On 2/23/2012 1:38 AM, Deepali Patil wrote:
> 1) In pom.xml set<birt.runtime.location> to the lib of ReportEngine.
> Deepali.
Re: .odp and .odt formats gives exception [message #805953 is a reply to message #805502] Fri, 24 February 2012 05:37 Go to previous messageGo to next message
I use the pom given on link http://www.birt-exchange.org/org/forum/index.php/topic/24196-mavenizing-birt-3-7-1/page__s__22a7ecc0cee225f7eb3ac8c3399c5491
still gives same exception.
Deepali.
Re: .odp and .odt formats gives exception [message #808385 is a reply to message #804930] Mon, 27 February 2012 13:25 Go to previous messageGo to next message
I just opened a bug for this. It appears to be an issue in 3.7.1 and 3.7.2.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372671
Jason
> Deepali.
Re: .odp and .odt formats gives exception [message #808780 is a reply to message #808385] Tue, 28 February 2012 00:59 Go to previous message
Thank you.
Deepali.
Previous Topic:Duplicate reports
Next Topic:Parameter Display Value
Current Time: Sat Jul 26 06:19:55 EDT 2025
Powered by FUDForum. Page generated in 0.31325 seconds
