Home » Archived » Buckminster » Buckminster for Non-osgi projects(Buckminster for Non-osgi projects)
Buckminster for Non-osgi projects [message #804198] Wed, 22 February 2012 05:05 Go to next message
Can we use Buckminster for Non OSGI projects?
Suman
Re: Buckminster for Non-osgi projects [message #804238 is a reply to message #804198] Wed, 22 February 2012 06:06 Go to previous messageGo to next message
> Suman
Yes, but you'll need to add cspecs to your projects and there is no build support provided out of the box.
- thomas
Re: Buckminster for Non-osgi projects [message #804927 is a reply to message #804238] Thu, 23 February 2012 01:34 Go to previous messageGo to next message
Thanks for response.
Does it mean, we need to manually prepares .cspec or .cspecx files?
Suman
Re: Buckminster for Non-osgi projects [message #805064 is a reply to message #804927] Thu, 23 February 2012 04:44 Go to previous messageGo to next message
> Suman
Buckminster can be made to recognize your projects on one of two ways.
1. Use a buckminster.cspec file at the root of the project. This is the simplest approach.
2. Create an extension bundle for Buckminster that contains a component type/reader type combination that can make sense
of other files in the project and generate a cspec based on them. This bundle must then be installed into Buckminster.
Buckminster is bundled with extensions that makes it possible to use approach #2 for plug-ins, features, and maven
projects (contains a pom.xml).
- thomas
Re: Buckminster for Non-osgi projects [message #805291 is a reply to message #805064] Thu, 23 February 2012 10:37 Go to previous message
In addition to what Thomas suggested - there is nothing preventing you
from using OSGi metadata even if you are never going to be running your
components in an OSGi container. i.e. "stick your stuff in a bundle".
- henrik
>> Thanks,
>> Suman
> simplest approach.
> type/reader type combination that can make sense of other files in the
> approach #2 for plug-ins, features, and maven projects (contains a
> pom.xml).
> - thomas
Previous Topic:hudson buckminster.json
Next Topic:Build eclipse project from ANT script
Current Time: Wed Jul 23 18:36:37 EDT 2025
Powered by FUDForum. Page generated in 0.04059 seconds
