[Teneo]Cannot create mappings for emf's XMLNamespace model [message #80250] |
Wed, 18 April 2007 01:36  |
Hi Martin,
I don't actually have to persist this model but I thought you should know
that Teneo fails to generate mappings on this package:
org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage
Attached is a plugin to duplicate.
Let me know if you want me to file a bugzilla.
-mike
org.hibernate.MappingException: invalid mapping
at org.hibernate.cfg.Configuration.addXML(Configuration.java:38 2)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapModel(HbDataS tore.java:367)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:156)
at test.teneo.MapTests.createHbDataStore(MapTests.java:67)
at test.teneo.MapTests.testSaving(MapTests.java:81)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: org.xml.sax.SAXParseException: The content of element type "id"
must match "(meta*,column*,type?,generator?)".
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
Source)
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. error(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(Unknown
Source)
at
Source)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. handleEndElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. endElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanEndElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at org.dom4j.io.SAXReader.read(SAXReader.java:465)
at org.dom4j.io.SAXReader.read(SAXReader.java:365)
at org.hibernate.cfg.Configuration.addXML(Configuration.java:37 9)
... 22 more
Re: [Teneo]Cannot create mappings for emf's XMLNamespace model [message #80284 is a reply to message #80250] |
Wed, 18 April 2007 04:51   |
Hi Mike,
Thanks for letting me know. I used your testcase and yes this is a mapping error. Can you enter a
bugzilla for this? Then I'll solve it for the next release.
gr. Martin
Michael Kanaley wrote:
> Hi Martin,
> -mike
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> ... 22 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Cannot create mappings for emf's XMLNamespace model [message #80379 is a reply to message #80284] |
Wed, 18 April 2007 11:32  |
Bugzilla 182989 has been submitted to track this.
-mike
"Martin Taal" <mtaal@elver.org> wrote in message
news:f04m6f$cpv$1@build.eclipse.org...
> Hi Mike,
> error. Can you enter a bugzilla for this? Then I'll solve it for the next
> release.
> gr. Martin
>> Hi Martin,
>> know that Teneo fails to generate mappings on this package:
>> Thanks,
>> -mike
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> "id" must match "(meta*,column*,type?,generator?)".
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> ... 22 more
> The Netherlands
Re: [Teneo]Cannot create mappings for emf's XMLNamespace model [message #604840 is a reply to message #80250] |
Hi Mike,
gr. Martin
> Hi Martin,
> -mike
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> ... 22 more
The Netherlands
Re: [Teneo]Cannot create mappings for emf's XMLNamespace model [message #604865 is a reply to message #80284] |
-mike
> Hi Mike,
> release.
> gr. Martin
>> Hi Martin,
>> Thanks,
>> -mike
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> ... 22 more
> The Netherlands
FUDForum. Page generated in 0.32711 seconds
