If stereotype B is a generalization of stereotype A, does B inherit the meta-class [message #800892] |
Fri, 17 February 2012 11:48  |
Until recently I was using an older version of Eclipse UML2 (2.4) where this worked. After updating to Eclipse UML2 3.1, I receive an IllegalArgumentException when attempting to apply a stereotype generalized from another stereotype to an element of the appropriate extended meta-class. Stepping through the eclipse uml source showed that the attribute "base_Class" was missing in the underlying Ecore model for the stereotype.
Java test code:
// Init a resource set to load the standard UML profiles
ResourceSet rset = null;
rset = new ResourceSetImpl();
rset.getPackageRegistry().put("...", UMLPackage.eINSTANCE); // Forum filter prevents me from posting this: h_t_t_p_:_/_/www.eclipse.org/uml2/3.0.0/UML
// Register the UML resource factory
rset.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
// Get one of the standard profiles to build a jar path
final URL url = ClassLoader.getSystemResource("profiles/UML2.profile.uml");
if(url == null) {
throw new RuntimeException("Could not load 'profiles/UML2.profile.uml' from class path");
// Need the jarfile path so chop off the file specific stuff
final String path = url.toExternalForm().split("!")[0] + "!/";
// Build a uri for this path
final URI baseURI = URI.createURI(path);
// Build mappings from 'pathmap://UML_PROFILES' (or metamodels or libraries) to the point at the jarfile path
final Map<URI,URI> uriMap = rset.getURIConverter().getURIMap();
// pathmap://UML_PROFILES
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), baseURI.appendSegment("libraries").appendSegment(""));
// pathmap://UML_LIBRARIES
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), baseURI.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), baseURI.appendSegment("profiles").appendSegment(""));
// Load the test profile
Profile test = null;
final URL url = ClassLoader.getSystemResource("profiles/test.profile.uml");
if(url == null) {
throw new RuntimeException("Could not load 'profiles/test.profile.uml' from class path");
final Resource r = rset.createResource(URI.createURI(url.toExternalForm()));
r.load(null);
test = (Profile)EcoreUtil.getObjectByType(r.getContents(), UMLPackage.Literals.PROFILE);
if(test == null) {
throw new RuntimeException("Could not load 'profiles/test.profile.uml'");
Stereotype A = test.getOwnedStereotype("A");
Stereotype B = test.getOwnedStereotype("B");
Model m = UMLFactory.eINSTANCE.createModel();
org.eclipse.uml2.uml.Package pkg = m.createNestedPackage("pkg");
org.eclipse.uml2.uml.Class c1 = pkg.createOwnedClass("c1", false);
org.eclipse.uml2.uml.Class c2 = pkg.createOwnedClass("c2", false);
pkg.applyProfile(test);
c1.applyStereotype(A);
c2.applyStereotype(B); // throws IllegalArgumentException
Test profile is attached.
Re: If stereotype B is a generalization of stereotype A, does B inherit the meta-class [message #803776 is a reply to message #800892] |
Tue, 21 February 2012 14:56  |
Hi Lance,
This should work perfectly fine. B does inherit the extension and applying
the stereotypes should work.
> the stereotype.
You can see in your test.profile.uml that the base_Class property is there
in the ecore model.
I ran your example code and only had to adjust the base URI part a bit
because in my setup, the models were not found on the system classpath.
After that, your code worked perfectly for me with Eclipse UML2 3.2.100.
Carsten
FUDForum. Page generated in 0.40534 seconds
